1 - 18 of 18 Posts
Hyundai Kona EV 64kw Premium SE
Anyone know how to fix this without having to deal with Hyundai?
Started happening today and comes up every time the car is started.
EDIT - better picture!
134113
Kona EV 64Kw Premium SE in Galactic Grey
I like the effects, just before you go into hyperspace? Must be a new option on the MY 2020 :ROFLMAO:
I presume you have switched the noise off and on?
Yeah, nothing happens. We’ve got no sound, so watch out pedestrians!
Interesting - is this a 2020 model ? The 2018MY doesn't give any error if the VESS unit is unplugged, but I think VESS is now mandatory so that may explain why it checks it now
Does the 2020 have a switch to disable VESS?
Interesting - is this a 2020 model?
Yes, and yes. Down and to the right where you can turn off the Lane assist stuff.
Doesn’t make a difference if we turn it off and on again.
“Checked it. Yup, it’s broken. Carry on.”
Maybe VESS in a new car just requires calibration on several pedestrians, preferably in conjuction with the automatic emergency braking AEB ? :geek: You should just check it! :cool:
Discussion Starter #10
update - booked into Hyundai in September. Ugh.
Discussion Starter #12
Have you checked fuse to speaker? Fuse diagram says Memory 2, 7.5a fuse, VESS speaker
Yeah looks ok unfortunately
Discussion Starter #14
Please don’t spam.
Kona Electric, EU base with heat pump
Please don’t spam.
According to research done by another owner, CAN heartbeat messages from the VESS in the normal state are not required, which is why disconnecting the cable causes no error. The only way an error could be noted by the system is if the VESS intentionally sent such a message. As such, pulling the plug should remove the error message.
Kona EV, 64kW Premium Nav 2019
Please don’t spam.
Odd comment. I didn’t read that as spam, but as a genuine suggestion.
Have you tried unplugging it to see if the error disappears?
Reactions: KiwiME
Discussion Starter #17
There was a deleted comment trying to get people buying stuff. :)
Discussion Starter #18
The comment I replied to was trying to sell stuff, ow deleted.
And no, I don’t seem to be able to get my hand at the right angle to unplug.
Booked in to see Hyundai in September now.
1 - 18 of 18 Posts
