1 - 11 of 11 Posts
Volkswagen e Golf Production:
It won't be long before these come to our VW showrooms.
Coming from a VW scirocco I really miss the German build quality and feel that's lacking in the LEAF. But, I find it a real shame that VW did not install a 32A onboard charger in this E-Golf! With no option of upgrading the 16A either! What were they thinking???
Anyway who else is looking forward to the E-Golf?
Great video, thanks for posting!
What's the range like in one if these?
The battery is slightly larger than a LEAF. So I would assume maybe 100 miles on a full charge.
But only 16a charging? Crazy. That's not improving the marketplace at all.
both are AC either type 1 or type 2 connectors are supported in the UK. Leaf (new model) has 16amp type 1 as standard but you can optionally buy it with 32amp
Basically it will charge nearly twice as fast with 32amp than 16 amp
Next question then; how often do people use 32amp charging ? Is home charging generally (always) 16 amp ?
Just trying to work out the logic; if VW think you are going to rapid charge on DC and home charge on 16amp AC maybe they thought 32amp wasn't worth bothering with.
And another question, does having a 32 amp charger cost more and if so why ?
Home charging, depends on your car, no point putting a 32amp charger in if your car only takes 16amps unless you are planning for the future
yes you could get (until OLEV put a hold on free chargers) a 16 amp charger for free but had to pay an extra £95 if you wanted the 32amp version. Upgraded components in the 32amp one, and the government grants were only for 16amp versions
I was surprised to learn that. The i3 is 32 amp and charges at the full 7.4 kw which I really appreciate as it can fill from empty to full in just over 3 hours which feels fast. The golf brochure is quoting 8 hours to charge.
With the fast charge option on the LEAF rated at 32 amps why does it charge at just 6.6kw and not the full 7.4kw that's possible on a UK domestic supply?
1 - 11 of 11 Posts
