Yup! and just to add, 43kW AC may only seem slightly less than 50kW DC.. it was far from it. My ZE40 Q90 felt ridiculously slow compared to my 24/30 Leaf Chademo.As above, there was never a Chademo option. There were however rapid charge options.
Q210 22kWh and Q90 40kWh supported AC Rapid of up to 43kW speeds.
The new ZE50 has optional CCS DC support.
All other Zoes support AC of up to 22kW.
AC43 Actually isn't terrible. You just have to satisfy the requirements in order to get a fast charge out of the Q90 Zoe. Plug in with a low battery that's warmed up from a good drive. You'll charge at 43kW (Before losses) for the majority of the time charging.Yup! and just to add, 43kW AC may only seem slightly less than 50kW DC.. it was far from it. My ZE40 Q90 felt ridiculously slow compared to my 24/30 Leaf Chademo.
I had a Q90 for four days and it charged at a maximum of 36kW at low SoC, and throttled back quite early. Only about 15 minutes quicker to 80% than an R90, which only charges at 22kW. Sure you’re not thinking of a Q210 or Q240?AC43 Actually isn't terrible. You just have to satisfy the requirements in order to get a fast charge out of the Q90 Zoe. Plug in with a low battery that's warmed up from a good drive. You'll charge at 43kW (Before losses) for the majority of the time charging.
No, definitely a Q90 since its a ZE40 and that's the only Q model to exist. I'm assuming the 36kW you're talking about was after losses? If so that sounds about right. By my calculations the fastest I've ever got into the battery is ~38kW.I had a Q90 for four days and it charged at a maximum of 36kW at low SoC, and throttled back quite early. Only about 15 minutes quicker to 80% than an R90, which only charges at 22kW. Sure you’re not thinking of a Q210 or Q240?
There were Q versions of the ZE22, I had one.No, definitely a Q90 since its a ZE40 and that's the only Q model to exist.
I meant the only Q Model of the ZE40.There were Q versions of the ZE22, I had one.
I think that’s what was referred to previously.
