1 - 20 of 33 Posts
· Registered
Well I have noticed a fair bit of dripping from the tailgate when I open it but I've always assumed it was water running off it, not *out* of it. I'll look next time I open it...I think we can safely say it will rain tomorrow! Where on the tailgate is water running out of on yours Paul?
· Registered
Well you could be right I suppose. There was so much of it that I have assume that it couldn't just be from outside. There was just too much of it to be just surface water IMO but I could be wrong.
I shall take a closer look tomorrow morning but I think it is running out of the drain holes in the rubber (silicone) seal on one of the sides.
· Registered
I don't have near the rain here in Colorado you do in the UK but the pattern of dripping when we do have it pretty much stays in the channels on either side of the hatch. This includes melting snow which we do have. Wind will alter this dynamic of coarse. I also haven't encountered the fogging of the tail lights even in wet weather so perhaps that was an early production issue.
· Registered
Water has been pouring out of the tailgate as before but today I noticed that the whole the water pours out of is a whole that should have a rubber bung in it.
So, not only is lots of water getting inside the tailgate but I have a rubber stopper missing.
· Registered
Paul, can you indicate exactly where the hole you mention is (photo perhaps?) I'd like to check mine...
· Registered
Discussion Starter · #9 ·
Ah thanks. I honestly can't remember if we ever had a gommet in that hole from new. We might have I suppose... it isn't something I would have looked for :)
That is the hole where all the water pours out from anyway. With the gommet in I wonder how the water would get out?
· Registered
Good point Paul, it's a bit worrying. I just looked at my tailgate with a torch(just got home) and I don't seem to have a hole or a grommet in that position! But I will look again in daylight tomorrow. Wonder if there have been some detail design changes here to stop water getting into the tailgate in later cars like mine, and that the dealer has 'fixed' yours by removing the grommet?
· Registered
Just looked at my car again Paul and realised what the hole in your photo is! You're missing the rubber bump stop which fits in this hole to cushion the tailgate closure, you've got the one on the other side but this one has got lost somewhere. That being said, I'm not clear why you should have water coming out of it.
· Registered
taylorgx said:
Suppose you could open the tailgate pour water in the hole and see where it comes out at the other end!
Gary
That's not going to work though as the tailgate is all up from that hole. Unless he used a hosepipe, that might work.
My guess is that they've missed some other rubber seals off higher up as well.
· Registered
We seem to have slightly different tailgate 'undersides' depending when the car was registered :)
· Registered
Discussion Starter · #18 ·
Surely not?
Of course, this is possible but it is very unlikely isn't it? I can't imagine vauxhall redesigning the tailgate in any significant way so early in production unless it was in response to a recall or something serious and we would have heared of that I am sure.
But I could be wrong! :)
· Registered
Car is booked in to the dealer for next week to fix the rear door lock button (not working) and to investigate the water in the tailgate.
Will be interested to hear the verdict Paul.
1 - 20 of 33 Posts
