Managed to wash the car for the first time in over a month - yes, it has been that long since it was dry enough for long enough to do that properly!.
Checking all the seal areas first, opened all the doors and cleaned around there. Nothing too awful, no unusual dirt traps but hey, the back door seals (at the top of the door) are crap. I don't understand why they are so bad, I've come from a load of Audis and Porsches - and before that Golfs, and I cannot recall such badly designed door seals. It's as if they are designed to channel water in or onto the metal door frame, so that when you open the door it dribbles in, rather than keep it out. Comments please.
Moving to the back I opened the hatch and was deluged by water coming out of the plastic trim areas into the boot and the parcel shelf. Pulled the panels for the lights and water poured out, pulled the lower panel and more, along with the jolly sound of sloshing water lying in the door. Question is, would this be simple condensation, however unlikely? Anyone else had this problem?
(Just thought - need to find the drain holes if there are any.)
I guess it's a trip to the stealer which I was hoping to avoid until the first service, which is a long way away for now.
