1 - 20 of 29 Posts
Can anyone find a tow car cheaper than a Tesla model 3? (& no the nissan env doesn't count as can only tow with 3 seats & less than 500kg!)
Polestar 2 costs the same as a model 3 long range but can tow more.
All UK options below:
Polestar 2
£1,000 Extra
Can tow up to 1500 kg (3,300 lbs)
Noise load of 90kg
Tow Bar is Semi-electric
Tesla Model 3
£1,000 Extra
Can tow up to 910 kg (2,000 lbs)
Noise load of 55kg
Tow Bar is Manual
I-Pace
£1,720 Extra
Can tow up to 750 kg (1,650 lbs)
Noise load of 45kg
Tow Bar is Manual
Ford Mach E
£ TBC
Can tow up to TBC
Noise load of TBC
Tow Bar is TBC
Nissan Ariya
TBC
So all over £40k then?
I think the Model Y will be rated to tow a bit more than the M3. But that’s going to be a little while before we see it here.
Polestar 2
£1,000 Extra
Noise load of 90kg
Tesla Model 3, Y, and X
£1,000 Extra
Noise load of 55kg
Tow Bar is Manual
I-Pace
£1,720 Extra
Noise load of 45kg
Tow Bar is Manual
Ford Mach E
£ TBC
Can tow up to TBC
Noise load of TBC
Tow Bar is TBC
Nissan Ariya
TBC
The Model 3 SR+ can also tow 910kg and is quite a bit cheaper than the Polestar 2.
The Model X can tow 2250 kg / 200 kg nose weight.
The Model Y can tow 1600 kg
I think the Etron and EQC can also tow.
Also the Outlander PHEV which is the cheapest of the lot.
2017 Golf GTE
As usual the Golf GTE has been overlooked. It can tow 1500kg - yes, as much as an Outlander. And in fully electric mode too although only for about10 to 15 miles apparently. GTE mode is reportedly best for towing.
I have not towed with mine but a good rew have been doing so since 2015. Mostly visible on caravan chatrooms.
£1,000 Extra
Noise load of 55kg
Tow Bar is Manual
Model X towing capacity is 2250kg
You missed:
Audi Etron: 1800kg
Mercedes EQC: 1800kg
However, they are certainly not cheaper than the model 3!
Volvo XC40 P8 is 1500kg, same as the polestar unsurprisingly (same car, different suit).
Other things forthcoming:
Skoda Enyaq: 1200kg
Presumably other MEB cars will be similar - audi Q4 etron, ID4, etc.
Apologies for the incorrect Y and X
I copied and edited this from another place, and was meant to remove the XY
The Y won't be in the UK until late 2021/early 2022 right? And the X isn't cheap.
And to the poor Golf GTE driver - it wasn't intentional to miss it off, I just didn't know.
With regard the GTE, then there's plenty of PHEV that can tow.
Volvo T8s can tow 2100kg
Volvo T5 Twin-engine can tow 1800kg
Outlander can tow 1500kg
etc
However, I suspect that towing with a petrol PHEV that struggles to get 30mpg on a motorway run even without towing (like the XC90 T8) is going to be a ruinous exercise.
Zoe Devotee
It doesn’t just quit and fire up the engine once you try and pull away?
I was under the impression the ICE motor wasn't attached to any wheels.
Probably a New Electric Ireland BMW "Panzer" or Lexus CVT-based electric conversion. Stunningly cheap!
Zoe Devotee
1 - 20 of 29 Posts
