Not yet. I guess someone will try, eventually, but most people's experience is of 'early life' failures. Few are high mileage failures.
I'm not keen on any transmission work being done in a regular garage environment. Really needs to be spotless conditions. But Vauxhall/GM are fixing this in a 'regular garage' scenario. I am not keen, but removing the whole transmission is a nightmare, this is a 'quick fix' of a job they basically 'discovered' they could do. (Originally, the bearing wasn't even available as a separate part, only as part of the motor rotor assembly.)
A removal/press tool has been devised to assist with this. Remove the wheel, suspension and drive-shaft, remove the outer casing, and the bearing is just there.
