Hello Electricians and EV enthusiasts,
Could some one explain why traction battery in EVs needs to be High Voltage instead eg. 12V or ~4V (single cell voltage)?
I understand that power is simply V * A. So technically you could have more cells joined in parallel delivering high Amps rather than serially (high Voltage / lover Amps for a given C rate). You should be able to charge / discharge low voltage battery at the same kW rate as high voltage.
Higher voltage increases motor spin rate but you can construct a motor that will simply spin faster / slower for a given voltage (my guess it mostly depends on motor winding but i may be wrong here). Just like transformer.
So why traction batteries cannot be 12 volt?
