1 - 9 of 9 Posts
Window wipers not working after a trip to the garage to sort out my suspension and my Aircon/heating as no rain on way home was not tested...then found out wipers are not working at all.. any one know were the fuse is for this if it's the fuse...??
You don't have model info in your signature or post. This is not for the ZE50 (I don't have it)
2020 Corsa E
Do they still fail to work when you use the windscreen wash?
Fuse panel is in the glovebox. The fuses are listed in the owner handbook.
Yes that's what Iam starting to think I will try but Iam layed up ill at this time...
I’d go back to the service and report what happened. It could be that, from the desire of giving a speedy service, they may have forgotten to re-connect the plug for the wipers motor.
shit happens, with the best intentions
Corsa-e Elite Nav 70 reg
Not the same problem, but my ZOE's rear wiper stopped mid-wipe yesterday. It didn't respond the the on/off switch, but when I tried using the rear washer, that kicked it back into life. Presumably a software glitch.
1 - 9 of 9 Posts
