1 - 20 of 21 Posts
So it's cold, (was a mere -3°C) I have appropriately mixed screenwash with de-icer in the washer reservoir.
Try to squirt some water onto the windscreen. Failed. Several times
Try to squirt some water onto the rear windscreen. Worked.
an hour later as the sun rose, both washers are working fine.
It seems to be that when Nissan designed the route for the windscreen washer piping, and the nozzles themselves, they were still designed with a big hot lump of an engine under the bonnet.
Does it not mean the anti-freeze mix you had added to the bottles had not yet reached all the way along the pipes. The old mix left in the pipes froze. Keep squirting (when it works) until you can smell/see the anti-freeze mix come through.
Just a thought that's all.
2019 Leaf 40
You'd think heated mirrors and heated washer jets would be standard on an EV. It's like they never think anyone would use one in the winter.
My 20 year old BMW had heated washers. It's not as if this is a new idea at all. It was a soft top too so essentially a summer car but it still had heated mirrors and heated washers.
I don't think this is a Nissan problem, it's an EV problem in general!
I have the same issue with my Ion. In winter I use screen wash with a -10C (or recently -15C!) rating and yet as soon as the temperature gets down to about -3C or less overnight either the front washer or the rear washer (sometimes both!) stop working and can't be persuaded to work for love or money...you can hear the pump pumping away but the nozzles are clearly frozen shut.
Most recently it was the rear washer that decided it wouldn't work but the time before it was the front one! :rolleyes: Short of getting a hairdryer onto the nozzles to see if it helps, once frozen they won't start working until the weather warms sufficiently. In one really cold spell I went for about 3 days without working washers because it was between -4C and -7C the whole time.
I can only assume that pure water condensation from the atmosphere forms on the opening on the nozzle and freezes overnight - thus the nozzles are blocked with ice regardless of what screenwash fluid you have in the car.
On an ICE the heat from the engine bay will warm the front nozzles so while they may not squirt immediately, once the engine bay warms up a bit bonnet mounted nozzles will thaw out. (Nozzles on wiper blades may be more of a problem)
And rear washers on an ICE probably get at least some heat from the exhaust, and also through the glass since people tend to keep the cabin heat cranked up in an ICE and turned down in an EV!
Due to the lack of copious amounts of waste heat I think EV's just need heated nozzles for washers to be reliable in cold temperatures... (n)
Just buy a better anti-freeze.
As noted, there's no engine heat to bail you out.
Can't recall the one I use, but it's a concentrate that goes to minus-something-really-silly
I guess you didn't read all the posts in the thread properly including the original one ? ;)
It doesn't matter what grade of screenwash you use. I still get the problem even with super strong -15C rated screenwash when the ambient temperature is only about -3C.
Hence my conjecture that the problem is caused by precipitation forming on the nozzles (which will be pure water) and freezing overnight, capping the nozzles closed. Doesn't matter what is sitting in the pipes or washer bottle if the ice on the tip of the nozzles is pure water that freezes at 0C.
I guess you didn't read my post properly.
-15C isn't a super strong anti-freeze at all.
Since buying one that goes a lot lower than that, end of problem.
My conjecture would be that the properly super-strong anti-freeze I use gives protection around the nozzles as well.
I've switched to Prestone concentrate, which goes to -23C.
Won the freezer test in recent Autoexpress by a good margin.
Working for me, no more frustration in NE Scotland temperatures.
The -15c concentrate needs to be virtually neat to be effective from what I remember. At most it's 50/50 dilution.
I'm just putting the concentrate in straight without diluting it.
I still get freezing nozzles that won't spray at about -4C. I think the nozzles are just too exposed to radiative cooling overnight on a clear sky and that normal frost that forms on the windows forms on the nozzles too.
What happens if you spray de-icer directly onto the nozzles? Does that free them up?
Haven't tried that - by the time I notice the nozzles are blocked I'm usually either already on the road (because the window started out clean but got dirty while driving) or I'm in a hurry to leave for work and we're already in the car ready to go.
But next time it's frosty I'll check the washers are working before leaving and give that a try.
2019 Leaf 40
I generally squirt the washers before driving off from home each time. Saves finding out later that they're not working. I do it all year round. Also means washer fluid doesn't stagnate quite so much either.
I don't like spraying de-icer near paint.
So if nozzles are ever frozen, I just use warm water.
Haven't had any issues since using the Prestone though, and it was -5C here the other night.
I think my screenwash pump is poorly. Does anyone know whether it's the same pump serving front and rear? Or two separate ones?
Has anyone replaced the pump/motor?
Sadly I can no longer hear a noise when I operate it.
I suspect it is two pumps as (when the screenwash level is getting low) I have found the rear screenwash was not working but the front one was still working - fixed by topping up the screenwash reservoir. This was in summer, so frozen jets was not a problem.
I think it a pity that Nissan did not fit a low screenwash warning light to the Leaf - something that I had learned to appreciate in my V-reg Primera.
I use this too. No freezing issues during beast from east
1 - 20 of 21 Posts
