Charged the car to 80% last night and range is showing 165 miles! Ah well, summer was nice, now the battery heater's started kicking in.
Very wet windy and heater needed drive last night. Wettest yet and pleased to say sure footed even with bridgestone tyres, ie flooded roads and rivers across road.I’ve done a fair few miles in the last couple of days - lots of short journeys and it’s maybe 5% worse?
61% and 134 miles for me, after driving 50 miles yesterday in the pouring rain and colder weather. I'm not sure how far back the GOM goes for estimating range as using yesterdays driving it would be likely be guessing around 117 for 61%.61% and 127 GOM miles here, on my 58kWh version.
Yes, the last few journeys I’ve done have been in the wet and wind, we’re definitely heading into the 200 mile max range period rather than the 240 now. 💦🍃❄
The battery heater seems to me to draw quite a lot of power initially then tapers off. Why can't VW enable the car to heat the battery when it's plugged in and you pre-condition via the app? This would increase the range if you're setting off on a long journey.AC seems to be pretty efficient, the most I've seen it draw is 1.7kwh when at max chat in a freshly opened hot car on a sunny day. Turning it off mid-journey only adds 2 or 3 miles to the gom before I remember life is too short and turn it back on.
It's obviously significantly less than the 4 or 5kwh I've seen for battery heating.
I leave the AC on permanently and have not noticed any major drop off in mileage, obviously every journey isn't exactly the same so hard to compare fairly but it's hardly as if it's enough for me to worry about the impact.
These are just figures I've noticed when stationary, doesn't mean they're gospel.
Got to agree with you, 95% of my journeys I don't even think about efficiency. Travel to my daughter's twice a month, round trip of 130 miles but I put it on the granny charger for 2 or 3 hours when I'm there to give me some wiggle room. Mega happy with car, no issues with software since 2.1 and saving a bomb on fuel. Hey tooks, whereabouts in lincs do you live, I'm just outside Lincoln?I drove from east Lincs to the North West yesterday evening, around 200 miles.
Very wet for most of it, ferocious side and then headwind as the journey went on.
Averaged 2.9 miles per kWh, average speed for the latter half of the journey was 62mph.
To be honest, I’m past caring what efficiency I get now, I could have done better should I have wanted to or if I’d had nowhere to charge up enroute, but I did so it didn’t really enter into my conscience.
This will be my third winter now in a 100% electric car, the second in the ID.3, and it’s just something I don’t think about and the car has become the tool it should be.
Agreed. Couldn't give a toss about efficiency when in the range of my home charger, but when out on longer journeys and reliant on the greater charging infrastructure, it matters.The trouble is as winter range decreases, the foibles of a poor EV charging infrastructure come in to play more, at least for those who have to travel longer distances. It isn’t just about the car.
We need a lot more progress in terms of EV charger numbers and their reliability/maintenance.
I actually live on the border between Lincs and Leics, but I’m stationed at a fast pointy jet base so travel from there a fair bit.Hey tooks, whereabouts in lincs do you live, I'm just outside Lincoln?
I find AC hardly makes a difference. Plan to keep it on all year round. Last time I tried to switch it off in a car, it became smelly over time and had to be cleaned. Not sure if this is an issue with the newer ACs ???I might add that I wasn't using AC or heating on my last 2 journeys with the efficiency dip, just the dipped beam as it was still dark when I set off.
It makes quite a difference when there's a significant differential between ambient temps and the temp you want, unless you use recirculation.I find AC hardly makes a difference. Plan to keep it on all year round. Last time I tried to switch it off in a car, it became smelly over time and had to be cleaned. Not sure if this is an issue with the newer ACs ???
