1 - 20 of 58 Posts
Had a smart meter installed by EDF a couple of years ago. The whole process was drawn out and ultimately unsuccessful. They kept cancelling appointments/not turning up, when the installation was eventually completed the meter wouldn’t connect to “their network”. Since then I’ve had to still manually submit meter readings.
We are in a bit of a black spot for mobile phone coverage and that was the reason/ excuse they gave us.
I believe from UK Electricity and Gas Smart Metering that the Aclara 1312 meter they supplied, is SMETS 1.
So I am wondering (with the impending arrival of an EV), whether switching to a provider such as Octopus, would get me a SMETS 2 meter that might actually work and give me access to better tariffs.
Is there any way of checking signal coverage before embarking on another lengthy and possibly unsuccessful process?
When Octopus (using subcontractor SMS) fitted my meter in June this year, they'd apparently checked some sort of database to conclude a SMETS2 wouldn't work here but the SMETS1 meter that was supplied seems to be working fine.
Octopus finally installed my meter 3 weeks ago and despite a visit from someone to audit the installation who confirmed everything was in order they still are receiving data to enable me to switch tariff.
As far as I can work out, the SMETS1 meters use the mobile network (which is why mine struggles), the SMETS2 use some other kind of radio network that connects as a kind of grid. I may have got this wrong!
It might be that your mobile coverage is good, but there’s no one else near you with a SMETS2. Or this other radio network doesn’t give you good coverage.
I’ve got the opposite problem, which I’m hoping a SMETS2 might solve. Could just do with an idea of what the coverage is like.
Might give Octopus a call next week.
Phone or email Octopus and ask them to confirm the smets2 signal status at your property.
I did this before starting the switch process, back end of last year.
They soon came back and said the reception was likely to be good.
I asked because mobile reception is variable at our location, mainly due to topology and an abundance of ironstone in the ground, hence the reason the village exists.
Smets2 meter does work and as it was an O2 based sim that is about the best coverage Here And what we use in our mobile phones.
I would ask for conformation from Octopus, but you can still switch and ask to get on their tracker tariff, which gives the low cost benefits, but with a dumb meter, just need to supply them monthly readings. You should eventually get a smart meter fitted by Octopus though.
Reactions: adobbing
SMETS2 meters can connect directly to the DCC and, where there is no direct connection, indirectly to the DCC by establishing a wide area network (WAN) with adjacent SMETS2 meters. A WAN connection is not supplier dependent but it does need other SMETS2 meters within WAN range and at least one meter within the network which can connect to the DCC. According to SmartME, you can tell if your meter has a direct or indirect connection by looking at the LED lights on the comms hub.
Quote: WAN - Wide Area NetworkShows your communication hub’s ability to communicate with your supplier. This light will be off if your meter is using the MESH network to communicate. Unquote
Smets2 meters are not all mesh enabled. Mine isn’t. Seems odd they are not fitting something that has connectivity redundancy as the rollout and comms reliability would be much better.
The situation is different between the north and the south of these islands. I think the mesh system (run by Telefonica) is only available in the south. In the north there is a long-range radio network run by Arqiva, so the comms hub part of your SMETS2 meter is likely to be different.
Actually, I believe SMETS1 meters can also work on a mesh basis through the zigbee HAN, but it's very low powered and unlikely to be of much use unless you live in a terraced house or otherwise right next door to someone else with a connection via the WAN. The WAN uses GPRS i.e. the data part of 2G/3G phone network.
If you live in a marginal signal strength area, it may help if you get a separate antenna fitted to your meter. Moving it around can help find that bit of extra signal strength occasionally.
Discussion Starter #9
Thanks for comments, learning all of the time on this subject.
I would have thought that living on the Wirral with a CH postcode, would put us in the north, but reference to north and south of Manchester makes me wonder.
I will try and give Octopus a call in the morning and see if they can confirm anything based on postcode.
My current EDF SMETS1 meter has never been able to connect, would be nice to have one that can!
An SKU1 marked comms unit has a single internal antenna that cannot be changed. SKU2 has an external antenna for cellular and an internal one for mesh. The SKU3 unit has an external antenna for cellular and a second external antenna for mesh. Comms units in central or south are marked usually with SKUx so you can see what you have. SKU1 does not have mesh SKU2 and SKU3 do.
Some pictures of an SKU here:
Installer Instructions here:
This might help. I live in North Shropshire and I was told that I was close to the upper limit of the Southern SMETS2 area.
134291
@lLexden The map suggests Shropshire is in the central area not the southern one. Perhaps the person who advised you has confused Shropshire and Somerset. :rolleyes:
Discussion Starter #13
Hi
Looking at that map we are directly under the black line at the top of area 9, which shows on the key as “SP Manweb”, this looks correct as they are/were the local power company and are our “DNO?”
Have just spoken to somebody at Octopus who said that we are an area of “high probability” of good signal strength.
He also told me that currently they are making appointments locally for the first week in October for meter installs. Advised me to call back the day service transfers to them, to expedite the process.
You can check cellular coverage for yourself here:
Just enter UK and O2 for the network.
Hmmm. That network coverage map looks distinctly over-optimistic for the situation round here. I've found the OFCOM checker more realistic as it gives the option of signal strength indoors as opposed to generic strength estimates (which more nearly equate to outdoors).
OFCOM postcode mobile phone checker
As before, the O2/Telefonica coverage is the one to look at. What I don't know is how well this works in other places around the country.
Discussion Starter #16
Move underway to Octopus and thank you to “Peter?” For the referral code.
Not yet got my new car, it’s a BMW that’s being held at the dealer due to a recall!
Now weighing up chargers, before I start a new thread, is there one that discusses the best prices/ offers/ deals for installation of wall chargers?
Discussion Starter #17
Bumping this as Meter installation took place and low and behold there is no signal!
This was the previous non functional meter fitted by EDF
136888
It has now been replaced with this non functional meter supplied by Octopus (SMS metering)😡
136889
Comment from installer was that there was no signal.
Just referred me back to Octopus!
I see various mentions of SKU 2 and 1 as a solution to this issue.
Any advice?
If there's no signal, then it's never going to work! Do you know if O2 mobile signal is usable within your house? (I'm assuming that's an in-house installation). Does the WAN light flash at all?
If that doesn't work, exchanging the comms hub (the top bit marked "Toshiba") with an SKU2 or SKU3 seems the way for them to go, but I suspect Octopus will ask you to give them a couple of weeks to see if they can see your meter first.
Give them a call and see what they say about it. But good luck - I had a failed SMETS2 installation, and it took a couple of months, though I've now got someone booked for next Monday. In my case, it was meters failing to commission properly.
Discussion Starter #19
Thanks.
Works mobile was O2 now Vodafone can’t remember signal being a problem and not now.
The only LED that is flashing is the SW one, others don’t
I take it the installer was a third party and not OctopusEnergy own installer.
if that’s the case then not really surprised, but disappointing that they don’t even attempt to resolve with other connectivity solutions. They can use other sims, an external aerial which is basically stuck on the outside of the meter box, so only any use if you have one which is on an outdoor wall. And then swap the comms part of the meter.
You need to chase Octopus and get them to sort out a solution plan.
1 - 20 of 58 Posts
