I'm asking on here to try to be able to diagnose the common Battery Charging Impossible fault.
So far I've had it 2/3 times when trying to rapid charge. Never when using 7KW or 22KW Posts.
First time it happened was at an Ecotricity Unit back in November, I originally was going to take it back to the dealer to have a look at but was advised by RZOC members to try another rapid.
As I don't have any local I made the journey to the next closest one which is a Pod Point unit and it worked straight away so I cancelled the dealership appointment accepting that it was the Ecotricity Unit.
Then yesterday I made a longish trip, could have made it easily to and from the destination if I had charged beforehand but knowing that at the location there was a free Rapid (The exact same pod point I used to verify the car was fine before) I left it a bit emptier where I could easily get to the destination but would need to charge to get home.
Got to the destination with 33% and it went to charge but then stopped, it tried a couple more times then BCI.
The symptom does seem a little weird, As it doesn't just refuse to charge at all (what I'd expect if its an earthing issue) but it charges for about 5 seconds then stops and loops until the Zoe BCIs.
Luckily the location had a 7KW post which I used to top up to 50% battery. I then went to try the rapid again but as I plugged in another car (Tesla) plugged in to the DC connection. The charger then started fine for the other driver but then the Zoe started charging fine too with CanZE reporting a rate of 22-28KW.
The interesting thing is if it was the earth as I keep getting told, the charger would not have charged at all even when the Tesla plugged in? CanZE Reported 39 Ohms on the Rapid and 7KW Post.
The only thing is that was the charger failing to deliver 43KW AC or is it that my car can't handle 43KW AC. It charges on 22KW Posts fine but both times my car has gone to charge at the full 43KW it seems to fail.
How do I clearly know if it is the charger at fault or the car?
