1 - 10 of 10 Posts
Hi
I'm currently on a Zappi v1 with a type 1 plug and want to change to a type 2. My installer has told me this isn't possible and recommending a v2 purchase. Sounds a big step back!?!
Has anyone else changed from a type 1 to a type 2 on a Zappi v1?
Thanks in advance.
Luke
If you check with MyEnergy they will supply the part and instructions.
myenergi_Lee said:
If the cable is purchased from myenergi and fitted in accordance with the instruction manual, then the warranty will not be affected.
If you can wire a plug you can so this imo.
Just turn it off at the mains first by flicking the RCB
It's slightly more complicated than a plug, the Zappi monitors the output with CT discs and they need to go back the same way they were removed.
It isn't complicated or difficult but does need care and attention to replace things the right way round.
1 - 10 of 10 Posts
