1 - 12 of 12 Posts
My wife just sent me a picture of one of the tyres on our ZE40:
146270
So it looks like we'll need a new one (what even happened there? I've never seen anything like it...). The tyres weren't exactly brand new when we bought the car last summer, so it is probably a good time to get a full new set. I'm a novice when it comes to tyres though - I remember reading somewhere that EVs need "special" tyres due to their weight - do I need to go for something with an XL rating like the Dynamos below? Or is that a load of rubbish and I'd be fine with a more premium standard tyre like the Goodyears?
146269
Discussion Starter · #2 ·
Related question - is that tyre safe to drive on (ideally I'd take that car to work tomorrow [11 mile commute], then drive it the the tyre place in the afternoon [another 10 miles or so]...)
Not sure I'd risk driving it like that... I'm still running on mainly original Michelin Primacy 4s but I've mainly seen people referring to Michelin Cross Climates as a replacement.
Michelin Primacy 4 is not a reinforced tyre, right? Or is it a reinforced version of the Primacy 4?
Zoe Devotee
Don't drive on that tyre. It may blow out at any time.
Why not just buy decent tyres rather than going for the cheapest? Cross Climates are well regarded. I used Dunlop Blueresponce on my Zoe for 2 sets and they were great, way better than the energy EV ones.
Discussion Starter · #7 ·
To be fair, the only reason I asked about the cheapest tyres is because those were the only ones on that list that had "XL" (as I said, I'm a novice when it comes to tyres!). I ended up going for the Michelin CrossClimate+ tyres at £99.98 each. Car is in the drive, and won't be moved until Halfords' mobile fitting team come to fit the new ones.
Seconded. This type of failure is one of the many that you can't cure with a a pump and goo. Somebody likely has tapped a curb, maybe a previous owner.
I've just had some more CCs fitted to the ZOE as the worn suspension had worn one to the legal limit on the inside of the tyre. The rest of the tread was over 3mm after 30k miles. Look at the load rating on your existing tyres - on ours it's 91 which means it's reinforced and we just bought the same...
2017 Renault Zoe (ZE40) Q90
I had Michelin CrossClimate+ on the front for over 18 months : very good (y)
Now have some Michelin Primacy 4 on the Front and find the car handle's slighty better (y)
You can fit cheaper tyres but just make sure they are XL , Extra Load or Reinforced ( 91 )
146411
Michelin do a budget tyre under the name Riken and cost about £48 each delivered from Cheap Tyres UK - Mail Order Tyres Online | CTyres.co.uk
146413
146414
A few weeks ago I replaced the front from-the-factory Primacy 3 tyres on my ZE40 with Primacy 4s as I noticed they were getting scrubbed on the outside of the tread - tracking was off. Once the tyres and tracking were sorted, road noise was a heck of a lot quieter!
And, of, course, fate being what it is - I had to replace a rear tyre on Thursday because it picked up an unrepairable screw in the sidewall 😡. Again, I fitted a Primacy 4.
1 - 12 of 12 Posts
