Car not charging at home (using charger and granny cable)
858 views 17 replies 5 participants last post by  Anarkid
Hoping this isn't a completely stupid question.
I've had my e208 for two years, and had no issues with charging it at two different properties. About three or four weeks ago, two months after getting a charger installed at my new house, problems started when leaving it plugged in overnight, only to find the car had barely charged overnight.
I'm on an Octopus smart tariff (IOG), and it seemed like my car was failing to wake up for the cheap slots. Except now I've realised that not only is my car not charging during the cheap slots, it's not charging past five minutes or so when I force a max charge on my Ohme charger, or even when plugging it into a three pin socket using my granny cable.
At first I thought it might be the dreaded AC charging issue, as the car charged just fine at commercial DC fast charging terminals, except I've just tested it using a commercial Type 2 AC charger, and it seemed to work just fine for the 15 minutes or so I left it plugged in for.
Does anyone have any ideas/tips/things to try? At the moment, I'm not sure whether it's a problem with the car, the charger, or my mains wiring, and don't want to have to fork out by taking it into the dealership unless I have to.
Thing to try: check your mains electricity supply voltage. Not because it's the most likely cause of the problem, but because it's fairly easy to test.
With care, a multimeter will show you; easier but only does the one job, a plug-in mains socket tester (mine's an Aneng AC10 but there are others); or you may have some appliance which reports, possibly even record, the mains supply voltage. Nominally 230 volts, usually about 240 volts in Britain, and the car should tolerate 216 to 253 volts without being fussed.
If it's out of range, contact your electricity supplier. If in range, keep looking for other possible causes.
Thanks - will try those!
We did have the charger re-installed and the garage electrics updated in our new house about 8 weeks before it all stopped working. I don't know if that's connected in some way, but it's the only change to our set-up since we first got the car (same Ohme charger, different house), two year ago.
Welcome to the forum. If the car charges OK on a public charger, then it kinda rules out both the car and your cable as being suspect. It's not clear what settings you might have changed to enable public on-demand charging rather than using a smart tariff or timers at home. It's not unknown for such car and tariff systems to fight each other. You could test that by deleting all car and wall charger settings that relate to tariff/timings to enable plug and go to see what happens. That may lead to some data causing you to look at the integration of Octopus and Ohme.
But also, as mentioned above, it's well worth checking your home electrics for adequate voltage as many EV's reject a charge if the voltage and/or AC 50 Hz is out of normal range. Also, there are many EVs that don't like an earthing impedance that is out of range. Sometimes, if the house is on an earth spike system, then different soil conditions in wet/dry conditions can change the impedance and many EV's refuse to charge if it detects a below-par earth signal. But even the more usual PME earth loop system can develop a fault that an EV doesn't like.
Well worth contacting the sparky who worked there a few weeks ago to check that earthing and voltage etc are in range.
But it also may be a bit of crud in your cable plugs/socket that intermittently works OK in public but needs a good clearout anyway.
Plot twist - the electrician has agreed to come out and take a look this Friday, but in the meantime, I had to drive a couple of hundred miles today, and when using a fast DC charger at the services on the way home, it charged for five minutes and then failed. Got back to the car with only five minutes of additional charge. I reconnected it and stood next to the car with it unlocked and watched it charge for 20 minutes, just enough to get me home again.
Made it back home and plugged my home charger in using the charge to max option, and it miraculously started charging for a full 90 minutes until I needed to use the car!
Doing more testing this evening, I can’t find any rhyme or reason to it. It managed a 90 minute charge earlier, only to then fail again within five minutes when I tried it an hour ago.
It’s currently charging fine using the granny cable plugged into the garage socket, so I think the garage wiring must be fine, and I’m back to the 12V battery theory. Tearing my hair out here 😂
#18 ·
Final update (hopefully). I eventually ended up taking it into the dealership and paid for them to do a diagnostic on the car. Apparently there was a software update needed for the onboard charger and as of last night, that appears to have fixed it.
Hoping there won't be any further charging issues - thanks all for your help, it was great to be able to count various things out.
