I have a four year old system with 20 solar panels, an 8.2kWhour battery and a 5 kw inverter, all Givenergy. Over the last three cold days my battery has not been charged from mains despite working before . The inverter is set to charge from 2330 to 0530 using Octopus Intelligent Go but has failed to do this despite three calls to Support at Givenergy when they tried various remote options. I have tried locally to turn the mains to the inverter off and on plus switching the battery off and on again. Strangely the battery is charging from the solar panels , but obviously not at a high rate due to patchy snow on the panels and limited sunshine. Givenergy say to monitor it over the next few days but cannot offer an immediate solution. I am wondering if it is temperature related as the garage has been at between 3 degrees and zero degrees overnight. It is 20 metres away from the house so gets no heat transferred from the house.
Any suggestions or similar experiences?
