Hello folks 👋 I'm hoping to get some advice on the following situation.
I am currently in the market to buy a Zoe. I have found an R135 20 plate that is just under £13k with <10k miles and is has just passed its MOT. This is from a non-official (i.e. not Renault) local dealer, where the car has only done ~400 miles in the past year. I assume the garage took ownership in the last year, and the car has been sat in storage most of that time.
I was planning to go buy this car this Saturday morning, but now I am hesitating.
The AA went and inspected the car this week, on the phone the inspector said the car was in good general condition and drove well. However, the written report says in big letters "Essential & advisable repairs required - not suitable for purchase unless all essential repairs are undertaken and advisable repairs, if any, are planned and budgeted for" - standard AA language.
The reason for this was the diagnostic trouble codes (DTCs) that were detected that he said warranted further investigation. These codes appear to be non-standard, without much readily available information online. The really scary looking ones are all in 'memory' - my understanding is that these were previously present, but are no longer active.
My question to you folks is - given the DTC output below, am I silly to proceed with the purchase as-is?
Thanks in advance for any help / tips you folks can provide.
Code:
Fault, 2, UCH (unite centrale habitacle)
DTC Code, DTC Status, DTC Content
DTC57137A, Memory, Wheel 3 flat Fluid leak or sealing failure
DTC57137B, Memory, Wheel 3 flat Low Fluid level
Fault, 1, Parking brake
DTC501586, Memory, No UCH multiplex signal Invalid signal
Fault, 5, Telematic ctrl unit
DTCAE138F, Memory, USB telematiic ECU connection
DTCAE16F0, Memory, Communication protocol error Time out communication
DTCAE1706, Memory, Telematics unit authtication not available Authentication error
DTCAE2209, Memory, Sim card Deactivated SIM
DTCAE2306, Memory, Gsm network registration declined Authentication error
Fault, 3, BCB (battery charger block)
DTC061263, Memory, S2 Relay Circuit/component protection expired
DTC067019, Memory, Neutral current sensor Circuit voltage above threshold
DTC069094, Memory, Charging terminal voltage inconsistency Unexpected operation
Fault, 1, BMS (battery management system)
DTC1B2081, Active, Dc charging relay circuit
Fault, 6, EVC (electric vehicle computer)
DTC15A731, Memory, Control driver voltage
DTC162986, Memory, Leakage current
DTC163D01, Memory, Charging socket lighting control module
DTCE34282, Memory, DC/DC not detected by HEVC Sequence counter active/incorrect/not updated
DTCE37094, Memory, Charger Unexpected operation
DTCE37096, Memory, Charger Internal component failure
