Having had a few different EVs I decided I'd get the one I have been avoiding buying for a while. The early model S. Picked it up yesterday. It's a July 2014.
Ease of use. You just get in and it's ready to go and your music is on. No faffing.
Seat - fully electric and very adjustable. Also found it surprisingly comfortable.
Navigation is good with built in charge stops that are clear and easy. Decent instructions.
Ride quality - better than I expected. It's on coils and on the daft 21 inch wheels but it's not the general bone shaker I was expecting.
Standard stereo is better than I expected.
EPB. You can push P once lightly to get the auto hold. I was expecting that you'd be able to just press the accelerator and just get going but it seems to want the full brake pedal push and put it back into drive. This is a bit irritating. Also had a warning about parking brake not releasing properly when I used it the second time which isn't great. Every other EPB car I've had just lets you drive off and it drops the brake off as you set off. Is there a setting I've missed that would enable it to be a bit more normal?
Few dash noises and wind noise. Definitely need to sort those out. There is at least only a couple of noises unlike the Corsa which was just a lot of noises with a hint of car.
The car as the over all package is definitely far better than anything else I've tried so far.
Not got access to the app yet.
Build quality isn't as good as the Leaf seemed but it's definitely better than Renault/Vauxhall etc.
No idea about the wipers. There isn't anything marked 'auto' on the stalk and no settings in the main car information. I'm assuming the stalk is 0 for off and the bars are sensitivity settings? Or are they actually just plain manual wipers with just 4 speeds? I forgot to check.
