Controversial? Surely not. Starting at about the 1 minute mark ...
More precisely, most households have a 15 kVA supply (i.e. about 63 A continuous since the nominal 230 V power is usually close to 240 V), with an 80 A or 100 A fuse to protect against supply cable overload. That 100 A fuse is not a licence to use more than 63 A for an hour or more, just a cut-off with a decent margin for short-term overload without needing lots of emergency callouts to replace the fuse in the service head. Some domestic supplies have a lower than 15 kVA rating, but I don't remember the details (need @Jeremy Harris for those).Today, most households have single-phase and can have up to 100A supply, albeit some regions now seem to try to limit to 80A.
Yes, agreed.More precisely, most households have a 15 kVA supply (i.e. about 63 A continuous since the nominal 230 V power is usually close to 240 V), with an 80 A or 100 A fuse to protect against supply cable overload.
They are thinking of the household with 3 EV charge points, charging on all of them overnight ready for going off to work next morning, next door to the same-sized house with a retired person living in it, who uses one car and rarely charges it at all. One's drawing 96 amps and the other about 1 amp overnight. Far better to have the three charge points on a phase each, or even three 3-phase charge points.I'd think uprating the standard single phase to 120 amp and having better supply cabling would be cheaper.
How does using all 3 phases to a property instead of having single phases to a group of 3 and balancing that improve things? It just sounds like a lot more cable as you have 3 runs instead of one fat one.
My electricity meter is at the back, the gas is at the front - I already have communication problems. If the electricity meter was at the bottom of the garden I don't think I'd get any data at all!4. More smart metering problems, the electric meter is now at the bottom of the garden, the gas meter which talks to it is at the house, the IHD is somewhere in the house. You'd expect there will be more local comms problems because the signal strength will be worse.
Not sure what is better. One phase each over three houses or three phases to each house and they all have multiple chargers, accidentally plugging into the same phase by chance. It's likely to be rare but given enough installations it will happen.They are thinking of the household with 3 EV charge points, charging on all of them overnight ready for going off to work next morning, next door to the same-sized house with a retired person living in it, who uses one car and rarely charges it at all. One's drawing 96 amps and the other about 1 amp overnight. Far better to have the three charge points on a phase each, or even three 3-phase charge points.
Home EV charging is especially lumpy, being big loads but not necessarily at the same time as the neighbours (unlike heating, for example, where every house gets the cold weather at the same time).
As in you have HAN or WAN communication issues? On the latter moving the hub to another location on the property might help or hinder. On the former, the premise in this setup is that 3-phase electricity replaces both the single phase connection and the gas connection, no worries about HAN comms issues.My electricity meter is at the back, the gas is at the front - I already have communication problems. If the electricity meter was at the bottom of the garden I don't think I'd get any data at all!
Well they won't be digging up the garden, you will when you are ready. The cabling after DNO cut off is yours to sort out.So ditch all the existing cabling and run new by digging up hundreds of rear gardens and/or access roads.
Not convinced they will be considering such disruption. I suspect we would have one of these in the front and only those who are doing major work on their house will make use of more than a single phase
Yes free to me, paid for from the greater good! 😁It's free in the sense that smart meters are free. I.e. everybody pays for this through their energy bills over a long period of time. The only money in the system is either a levy on energy suppliers -> energy bills or general taxation and I don't think it will be the latter.
It's largely to do with neutral current and balancing the phases.Not sure what is better. One phase each over three houses or three phases to each house and they all have multiple chargers, accidentally plugging into the same phase by chance. It's likely to be rare but given enough installations it will happen.
I wasn't referring to my garden, I was referring to all the gardens and small access roads the grid would have to go through to reach my back garden .Well they won't be digging up the garden, you will when you are ready. The cabling after DNO cut off is yours to sort out.
Aren't the chargers built into most cars capable of taking a range of power inputs - from 240v AC at 10A all the way to 800v DC up to about 400Amaybe the power companies will be asking that car makers install 3 phase on board chargers in cars for the UK market
