I see the issue over Octopus Intelligent comes up on several sites working with certain EV's and the issues over who controls what.
Someone mentioned if you want Octopus Go with 2 extra hours of cheaper rate electric and needing it connected to the car for a least 1 day in every 30 then OI is the way to go.
I run a home with 4.5kW solar array and 10kW home battery storage. Now I have the Kia E-Niro gen1 to charge up.
I can set my Project EV charger to work in Eco+ mode that will when left connected to the EV will send send surplus Solar Power to the EV and not to the grid. It's what I hoped would happen. However it only works when the power being sent is greater than 1.32kW and is a bit temperamental in days where the sun doesn't always shine well. In other words on partial cloudy days it doesn't always seem to just start up of it's own accord when the sun starts shining again.
My question is:-
Has anyone found with the OI tariff that if you leave the car to send surplus solar electric to the car OI will override this and send the maximum 7.3kW to the EV as they appear to control what is sent to the EV and when, up to your car's settings ( i.e) only charge to 70% or only send maximum of 30kW ) that kind of scenario?
My worry is that when OI determine when to charge the car, for those with home solar batteries it will draw from the battery overnight on the cheap rate leaving the house empty of cheap rate home battery charge power to use on the house during the day.
Any thoughts on how someone might have made this work well for them?
My question is:-
