The door handle thing🤷‍♂️
271 views 7 replies 5 participants last post by  AndyUK
So I got my S back today, apparently fixed but my S has started doing the same weird things today..AGAIN!
The nearside front and rear exterior handles wont present when I press the fob, they wont even pop out if you push them in slightly either, the drivers side is working normally.
Also, you can't operate the passenger windows from driver door control panel but the windows work from the switches on the nearside doors themselves.
Also nearside door mirror wont adjust from driver door panel either.
These faults are/were intermittent and its been back with the dealer I purchased it from for nearly 3 weeks. I got it back last night and the handles/windows were working as normal and now they dont....so im at a loss here.
Has anyone had this issue and can advise?
TIA
David
It's the wonder of them. Odd behaviour. Are there any messages in the service page moaning about something?
I would check doors are all shut properly and the door rubbers are all correctly positioned. I get window open errors when the rubbers have fallen a bit. I have to open each door and push them back up every so often. It's p not that but worth ruling it out,
I'd probably also change battery in the key fob. Also if the 12v has got low that might make it do weird things. Also check for damp carpet or boot areas in case water has got in and that is why it's strange.
Mine was odd when I first had it too. Sometimes they seem to freak when they haven't been in their usual place for a bit.
