If I search on mytyres.co.uk for 205 60 R16, choose extra options & select C-type (Van) tyres, it comes up with a single Hankook offering. Efficiency rting in the dry is D - translates to Dismal! Going to clobber your range I expect.
Change the options instead to Extra Load/Reinforced and also Electric-optimised tyres, it finds a lot of choice.
These are the ones I'd consider, as I'd want an A rating for efficiency.
Michelin E Primacy 205/60 R16 96H XL EV ÂŁ201 & A-rated for energy efficiency. Darned expensive! the 55 size is about half this! Avoid.
Continental EcoContact 6 - ContiRe.Tex 205/60 R16 96H XL CRM EVc ÂŁ119.87 limited stock.
A-rated for efficiency. CRM means some recycledpolyester yarn, EVc means optimised for combustion. hybrid & Electric cars. (The A-rating for efficiency I guess).
Continental EcoContact 6 205/60 R16 96H XL CRM EVc ÂŁ134.47 in stock. Looks the same tyre, but maybe a newer batch? Maybe a discount on the prev entry to clear out last-years run? I'd be tempted by that discount!
Continental EcoContact 6 205/60 R16 96W XL EVc ÂŁ141.47 limited stock. High-speed tyre, no point. Avoid.
Continental EcoContact 6 205/60 R16 96W XL EVc ÂŁ143.95 in stock. High-speed tyre, no point. Avoid.
Continental EcoContact 6 205/60 R16 96W XL EVc ÂŁ150.83 in stock. Expensive. Avoid.
Continental EcoContact 6 205/60 R16 96W XL EVc ÂŁ170.51 in stock. High-speed tyre, no point. Avoid.
Personally I'd jump on that ÂŁ119.87, get them to post you a set or 6, and then you can take them whenever to your local convenient fitter at your leisure. That one looks a no-brainer bargain to me.
blackcircles.com seem to have a smaller choice, but similar tyre makes & sizes.
