VAUXHALL MOKKA ELECTRIC WON'T START AFTER ACCIDENT
18K views 55 replies 27 participants last post by  Ethanedwards
2023 VAUXHALL MOKKA ELECTRIC WON'T START AFTER ACCIDENT, AIRBAGS BLOWN, WHEN TRIED JUMP STARTING IT ALL THE LIGHTS SWITCHED ON BUT WILL NOT GO TO READY AND I CAN'T PUT IT IN REVERSE, OR NUETRAL.
ANYONE WHO KNOWS ANYTHING ABOUT ELECTRIC CARS I NEED HELP PLEASE.
NEW TO E CARS SO HOW TO PUT IT IN NUETRAL OR START IT.
THANKS IN ADVANCE.
I suspect that as the safety system deployed the airbags, it has also cut the HV battery inverter relay incase any of the battery packs have sustained damage. Your going to have to get the vehicle recovered.
Hope you and everyone involved in the accident is OK.
The inverter is usually connected to main battery pack underneath the car. Please be aware that these vehicles operate on a 400volt system which has enough amps to kill you. They are not designed to be worked on by anyone other than a qualified EV mechanic. I would advise getting in touch with a HEVRA registered garage for assistance.
#9 ·
Whenever there is a crash the airbag module sets an error who can prevent the car from starting. If it is a heavy crash a different error is set that can only be cleared by a special proceadure on the dealership.
You can also check the pyrotecnic fuse, it is normally detonated on heavy crashes to quickly disconect the battery and will need to be replaced aftewards
In any case you should be able to move it out of park to N.
There is a reason why BEVs do that.
it's so you have to take out the battery pack and all the HV electronics for a safety inspection.
If you bought a written off BEV and have to come to an internet forum to look for inspiration, I think you've made an unwise purchase. Sell it on as it is.
Why do you think insurance on BEVs is sky high? Because they basically have to be totally dismantled and safety inspected after each 'bump'.
Welcome to the Brave New World of BEVs.
#19 ·
Exactly as @Aragorn has said, pyro fuse has blown. Absolutely do not in any way, shape, or form, do a DIY fix - it's lethal working inside the battery compartment without the proper PPE and training - DO NOT EVEN THINK ABOUT DOING IT.
400V DC is absolutely lethal, and there WILL be 400V DC present on exposed terminals adjacent to the pyro fuse.
Ignore the above if you are a qualified EV tech with the appropriate PPE and training. The PPE includes double insulated gauntlets, leather over-gauntlets, flash protection and a helmet with a certified flash protection face shield. You also need VDE rated footwear and VDE rated mats, together with approved test gear to dead test the connections you are working with, plus a 400V DC proving unit to be sure your dead tester is working.
#28 ·
SRS airbag ECU sends crash signal to other computers on the bus.
If it can be reset or not - does not matter. Has to come out anyway.
Only after fixing airbag system you can pass to next step - checking HV components - replacing any blown parts etc
After that a special procedure to re-enable the HV operation is needed.
It's very individual, and differs from manufacturer to manufacturer.
#35 ·
Yes. In the Corsa-e and Mokka-e it's located INSIDE the traction battery pack. So you'd have to 1 remove the battery 2 split the battery pack to get access to it. Highly dangerous and requiring specialised training/ equipment.
If you really want to do this, I'd suggest it'd be easier and cheaper to simply drop the original battery and replace it with a used pack from a scrapped vehicle. But again specialised handling of a high voltage battery is required.
#39 ·
In Peugeot EVs, the high-voltage (HV) protection system in case of a collision functions a bit differently compared to Tesla and many other modern EVs. This system is also used in models like the Mokka, DS, Corsa, e-208, and e-2008, as they share similar components.
In a Peugeot, when a collision occurs, the SRS Module sends a hard-coded "collision detected" signal to the TB ECU. This code, often something like P1B28, triggers the HV protection system to disable the HV Interlock Loop, cutting power to the transmission and motor.
In contrast, brands like Tesla, Mercedes, and Ford use a pyro fuse in such situations. When triggered, this fuse detonates, physically disconnecting the contactors and HVILs to shut down the HV system entirely.
#47 ·
Hi guys how did you get on with the HV lockout in the Peugeot? I do a fair bit of salvage and did a Porsche taycan last year with blown airbags and was easy to reset the HV battery once I got the software from an online forum, I’m now thinking of buying an electric damaged Peugeot 2008 for the missus but thought I’d check to see what the reset procedure is on pugs first as I can’t be arsed dripping the battery and splitting it to replace a pyro or what ever.
mark
