Zoe 2021 - AC Charging Impossible!
2 reading
1.6K views 22 replies 8 participants last post by  Bovril
So today when (I was supposed to) leave for work, with a fully charged Zoe mind you, I was greeted with a car that had not charged at all. I did a quick test where I took of the charging cable and plugged it back in, tried to start the charge, but it INSTANTLY started blinking red and the AC Charging Impossible was on the dash.
It doesn't even try to do any checks. When I press to start the charge on my wall charger it instantly fails. It doesn't even seem to try. Just red nose and the AC Charging Impossible. I don't have an ELM327 scanner and there's no local shops that sell these. I need to get the car charged for the weekend. What could it be? Could the 12V battery be on it's way out. It was changed last maintenance, but after that it saw very little drive for a couple of months. Although since then it has seen quite a lot.
Other issue I have had is that the trip meter has reset itself twice in the span of two to three months. Could these be connected. I'll go buy a battery tester and test out public CCS and AC charges to hopefully get some juice in the car as soon as I can, but if someone has any idea what could cause this I'd really appreciate it!
Thanks everyone!
For additional context;
CCS works, thankfully. At least I can use the car whilst it's expensive though. AC didn't work at a public charger either. Battery tester said that the batter is fine. Disconnecting the negative for 20 minutes did nothing, so something (probably expensive) is broken... Ordered an ELM327 dongle and will wait for it to ship. I'll want to do some self-diagnosing, before taking it to a stealership for diagnosis..
If anyone has ANY idea, I'd be more than happy! Thanks!
Welcome,
The most common reason for this BCI message is a poor earth. The Zoe is VERY fussy and requires an earth loop impendance of less that 150 ohms in order to charge from AC. If your home has an earth electrode to provide the protective earth then first thing to try is pouring a couple of buckets of water around it, as this will often reduce the earth resistance, so if this is the cause of the problem it may (temporarily) fix it.
If your home has a PME/TN-C-S or a TN-S electrical supply, where the protective earth is provided by your electricity supplier, then this may indicate that there is a genuine earth fault. I'm not familiar with the electrical distribution systems in Finland, so if you can provide a bit more information (perhaps with photos of your incoming electricity supply and earthing) then I can have a go at trying to give a more focussed answer. It is possible that this could be a fault with the car, but as supply earthing is a common cause for the BCI message it makes sense to try and eliminate that as a first step.
Hi and thanks for your reply!
I live in a row house, and the grounding of the building in this area is handled through the housing company and the main electrical distribution board, so I can’t directly influence it myself. However, I also tried using a public charging station, and AC charging didn’t work there either. I’ll have to try another public charging station this weekend. I can try to investigate the electrical system at home more closely, but I won’t be there until next week. The system is most likely TN-C or a TN-C-S combination, since most of the sockets are ungrounded, and the house was built before the 1990s
If the BCI message also appears when using a public AC charge point then I think that might rule out an house supply earth problem. Other known reasons for this message are earth leakage faults within the car. The air conditioning compressor is one known cause, as the earth leakage from that is also tested before the car will start an AC charge. Another known cause is an earth leakage fault in the motor, or in the BCB, the filter block. I'm not a Zoe expert at all, but do know enough to suspect that earth leakage, essentially an insulation resistance fault, seems to be a fault that has been reported here by others when the BCI message appears.
The reason this message doesn't appear when DC charging is because the car doesn't use the motor or BCB when DC charging. The Zoe uses the motor coils as inductors for its AC to DC switched mode charger, which is why it checks for earth leakage before requesting power from the AC charge point.
My daughter's car does this and my own has done it once. Do you have access to a granny cable? We cured ours by charging on the granny cable. We were able to charge normally the next time.
Okay, found a nice fella on the road whose charging outlet can be configured via software. So when put on 1 Phase, it doesn’t red nose, but it doesn’t charge either. The charger instantly says that the charging has been stopped and the car flashes yellow with ”Checking in progress..” and it does not go anywhere from there. 2P or 3P it instantly fails with the ”AC charging impossible” error..
#15 ·
I strongly suspect that this has narrowed down the fault to an insulation resistance breakdown on either L2 or L3, given that the BCI message comes up on 2 or 3 phase. Over here in the UK there is an independent EV repair specialist that has fixed this fault on a few Zoe's, Cleevely. There's also a member here, @G.a.r.y , who has made a few videos about repairing Zoe's, including this one covering the BCI error message:
Update #1500. 1P charge doesn’t work either, same issue. Tried charging the 12V but it’s okay. 12,8V when off for a while and 13,5V when the DC/DC kicks in. I’ll have to call Renault tomorrow and hope that there’s something they can do that doesn’t cost me an arm and a leg..
#18 ·
Update #1501 – This time with a happy ending.
I managed to source a vGate iCar Pro from someone who didn’t need it. I first tried the CanZE app, but on iOS it’s pretty limited—great for diagnostics and live data, but there’s no way to read or clear DTCs, as far as I know.
So, I went ahead and downloaded the Car Scanner app. I was able to read and clear the fault codes with it. There were a few codes, but they looked pretty generic, so I didn’t have high hopes. Still, after clearing them… the car started charging again!
I’m super happy it’s working, but the more I think about it, the more frustrated I get with the Renault engineers. Why is there a fault code that completely blocks AC charging, yet there's no visible check engine light or any other indicator? The only sign was an error message that briefly appeared only when trying to charge—and it disappeared as soon as the cable was unplugged. And why is there a persistent fault that doesn’t reset on its own, yet can be cleared with a $20 tool?
Anyway, bottom line: the car charges via AC again, and it only cost me twenty bucks! Still... what were the Renault engineers thinking??
Here are the codes Car Scanner picked up:
OBD-II
No DTC found.
ABS control unit (29 bit)
No DTC found.
S-GW3 (29 bit)
No DTC found.
E-ACT-EBA (29 bit)
No DTC found.
EVC-HCM-VCM (29 bit)
No DTC found.
INV-ME (29 bit)INV-ME (29 bit)
DTCs: 3
P0801(22) [0x080122] Archive (inactive)
Reverse inhibit circuit - circuit malfunction
Status: Confirmed, Test failed since last DTC clear
P0861(96) [0x086196] Archive (inactive)
Gear shift module communication circuit - low input
P0852(F2) [0x0852F2] Archive (inactive)
Park/neutral position (PNP) switch - input circuit high
BCB-OBC (29 bit)BCB-OBC (29 bit)
DTCs: 3
P0667(64) [0x066764]
ECM/PCM/TCM internal temperature sensor - range/performance problem
Status: Test failed, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
P0667(96) [0x066796] Archive (inactive)
P0690(94) [0x069094] Archive (inactive)
Engine control (EC) relay - sense circuit high
LBC2 (29 bit)LBC2 (29 bit)
DTCs: 1
U2143(81) [0xE14381]
Status: Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
LBC (HEV) (29 bit)LBC (HEV) (29 bit)
DTCs: 3
P1B0E(41) [0x1B0E41] Archive (inactive)
P1B20(81) [0x1B2081] Archive (inactive)
SRS/Airbags (11 bit)
No DTC found.
Power steering (11 bit)
No DTC found.
Dashboard/Instrument cluster (11 bit)Dashboard/Instrument cluster (11 bit)
DTCs: 1
U2113(87) [0xE11387] Archive (inactive)
Heater & air conditioning (11 bit)Heater & air conditioning (11 bit)
DTCs: 2
B24A5(14) [0xA4A514] Archive (inactive)
B24C0(09) [0xA4C009] Archive (inactive)
BCM (11 bit)BCM (11 bit)
DTCs: 3
B2C21(23) [0xAC2123] Archive (inactive)
Status: Confirmed
U1C00(08) [0xDC0008] Archive (inactive)
Status: Confirmed
C1714(7B) [0x57147B] Archive (inactive)
Status: Confirmed
EMM (11 bit)
No DTC found.
Sonar (11 bit)
No DTC found.
Hill start assist (11 bit)Hill start assist (11 bit)
DTCs: 1
C1015(86) [0x501586] Archive (inactive)
Status: Test failed since last DTC clear
Key hands free (11 bit)Key hands free (11 bit)
DTCs: 1
U215B(87) [0xE15B87] Archive (inactive)
Status: Confirmed
Multimedia system (11 bit)
No DTC found.
Emergency Call and Communication Module (11 bit)Emergency Call and Communication Module (11 bit)
DTCs: 5
B2E13(8F) [0xAE138F] Archive (inactive)
Status: Confirmed
B2E49(06) [0xAE4906] Archive (inactive)
Status: Confirmed
B2E23(06) [0xAE2306] Archive (inactive)
Status: Confirmed
B2E34(13) [0xAE3413] Archive (inactive)
Status: Confirmed
B2E17(F0) [0xAE17F0] Archive (inactive)
Status: Confirmed
Thanks everyone for your help! And for anyone coming from Google, try resetting your fault codes!
#21 ·
Hope so! This is the first issue I’ve had with the vehicle so far, and I’ve been super happy with it overall. The fuel cost savings have been a huge bonus—especially when charging at home here in Finland. On windy days, electricity prices often dip into the negatives, and during the summer months they hover around 0 c/kWh. Last month’s average price was 2.11 c/kWh, and the 12-month running average is 4.78 c/kWh.
It’s a great feeling to charge the car while technically being “paid” to do so—though of course, with taxes and fees, that’s not entirely true. Still, getting 1,000 km of range for under 10 euros isn’t uncommon with these smaller EVs.
