2014 Renault Zoe - Q210 How to find battery SOH?
2.9K views 2 replies 3 participants last post by  Sandy
Hi All, This is dynamique intens 2014 model with leased original traction battery. 8 years, so range has dropped significantly.
My question - Is this a good way of finding the battery SOH (state of health)?
I trickle charge the battery to 100%​
Then I reset the onboard range computer (using break accelerator reset trick)​
Then I see the new range is around 90 miles​
I believe the very original ideal range stated by renault for this model is 130 miles​
Then I divide 90/130. This gives me 69%​
Does this mean my battery SOH is 69%?
I believe if this procedure was performed when this zoe was manufactured it would be 130/130 = 100% SOH
Is my understanding correct? Or is there more to it? I know renault will not calculate it this way, but should this method give a good indication of the battery SOH?
Any help will be appreciated.
Thanks in advance
Nat
Way back when, that was the cheap 'n' cheerful way to check the range, as the 2-pedal reset removes all the driving data and resets it to the factory default. Of course you can buy an ODB2 reader and use the free CANZE app to read the SOH directly from the car itself. That will also tell you what versions of the BMS your car is running. It might be that flashing the latest BMS will magically release some extra SOH. That certainly happened 4 years ago when ours was surprisingly low - it went up from 81% to 97%. Now some 4 years and 40k miles later, it's back down around 80% :rolleyes:
Try my little formula. Proven to be pretty accurate.
