UPDATE ON NISSAN LEAF 2016 CARPLAY SOFTWARE INSTALL 2021/2
I'm now one month on from installing the Carplay software upgrade from
Xanavi. This is a summary of how it was done and my thoughts on the process. In the next post I will list the PROs and CONs. (These posts concern connecting your iphone by USB cable (which is how Xanavi is intended) - further down this thread I will write separate update on my experience of using this software alongside the
Carlinkit bluetooth handsfree device).
CAR: UK registered RHD 2016 Nissan Leaf Teka 30kw with approx 35,000 on clock.
PHONE: Iphone 13 with IOS 15 (Xanavi says it also works for Android phones).
KIT: 1x Xanvi software (ÂŁ199GBP on offer) at
Storeline ( think they are only UK suppliers)
1x 32Gb SD card (which stays in the car afterwards)(approx ÂŁ10).
1x USB to iphone cable (to connect your phone whenever you get in the car)
Computer with SD card reader & Internet connection (to download the software and write it to the SD card, and to get the install licence activated. You need this available and online midway through the install, so don't leave it at home and do the install in the car park at work!
SD card writing software (I used the one suggested in Storeline's instructions)
INSTRUCTIONS:
Amelia Connolly (who posts on this forum) is a sales advisor at Storeline and they have created a very helpful step by step install guide,
here which I will not bother repeating in detail. I have attached a PDF version to this post. Storeline has live chat on its website and a phone line and email.... they were pretty quick at responding to queries and very helpful.
DIFFICULTY OF INSTALL:
Very simple if your are reasonably confident at computer tasks like copying files and downloading. There's NO physical install or alternations to the car, it's all done with a software update ("flash") following the instructions in Amelia's guide in the link above. You can run through them online first as a practice.
Things to watch out for are:
1- This works with most Leafs but make sure yours is compatible (install guide explains this).
2- It says you need a Windows PC to write the SD card. I used a Macbook and it was fine.
3- The software is downloaded free from one of a number of sites, and then activated after install when you have paid for the licence. The software is about 20Gb, so download time will depend on your internet connection. My understanding is you need a 32Gb SD card as the "flash"process copies a back up of your original Nissan software to the SD card in case you want to revert to the original. But I have not tested this.
Download sites (check with the guide as these may change):
Europe:
8EU_20210929.img
Oceania:
File on MEGA
North America:
20 GB file on MEGA
If you want the Auto OK function of the SD you can add the file to the root folder from here:
auto_ok
IF you are paranoid about downloading files from the internet ... then you might have to run some virus software etc. I downloaded the file onto my Mac and then put it onto the SD card and have had no problems/trojans (yet!!).
4- The software for writing the SD card is here:
Windows here:
https://hddguru.com/software/HDD-Raw-Copy-Tool/HDDRawCopy1.10Setup.exe
Mac it's:
Etcher -
There is a video guide on how to write the data to the SD card:
5- There is a very clear video guide by Amelia
here on how to install the upgrade.
When you insert the SD card into your car, it starts the upgrade. This took about 15 minutes for me, with a couple of restarts. Annoyingly the car power cut off (went to sleep) part way through first time and I had to start again. I'd suggest turning the car on with your foot on the brake pedal (rather than just hitting the ON button twice) and that should prevent it going to sleep mid way through.
6- Once you insert the SD card with the new software into your car, the head unit will not operate UNTIL you get the new software activated. So it is worth contacting Storeline and planning how and when you are planning the install. That way you can pay for the licence, and know they are on standby to activate it. The way you activate it is to put the SD card into your car (switched on) and it will automatically let it "flash" the car's software - then you have to remove the SD card, and put it back into your Computer's card reader, and email Storeline a copy of the .DAT file (which the install will have created on your SD card). Storeline will then send you a .KEY file which you copy onto the SD card, which you reinsert into the the car, and that activates the software.
I did the software install late at night UK time, and sent off the .DAT file, and got the .KEY file back the next morning. I'm sure if you liaise with them, they can turn it round reasonably quickly. But to be on the safe side allow a few hours.
7- The whole process takes about 30 minutes PLUS time waiting for Storeline to send you the .KEY file.
8- Keep your original Nissan SD card safe just in case.
9- I understand there is a way to revert back to the original Nissan software using the new SD card /old SD card, but I have not tried this.
10- Once installed, Carplay will start automatically when phone connected to USB and car power is on. You can use MOST (see pros and cons below) functions of the original Nissan system, including radio, maps etc
11- If you leave Carplay (eg: by pressing radio button) you can return to us by going to APPS menu on touchscreen and navigating to Carplay)
12- When you first plug in your phone you will need to allow various permissions, which will allow Carplay to work even when your phone screen goes to sleep/is locked.
That's it! PROs and CONs to follow below.
Phil
