Haven't heard anything although I guess its good practice.
In Bjorn's review he did say the BMS behaved as if it was a 70kw battery so maybe they have built in a buffer rater than using something like trip mode in the Tesla.
On a vaguely related note I take it with Kia we buy the car & we own the battery?
Haven't seen leasing mentioned anywhere, but every time I mention I've bought an EV to someone they start talking about battery leasing for some reason I thought that was only Renault?
The semi-translated user manual includes this text:
AC Charging:
We recommend using the AC charger when you normally charge the car. You can use a standard charger at a public station, and the charging cable (if any) contained in the boot of your car. (See "charging AC", page 1-21.)
DC Charging:
You can fast-charge of public charging stations. Read each company manual that comes with each dc strömsladdartyp.
Battery performance and durability may be reduced if the DC charging all-time used.
To extend the battery life of the DC charge is used myck- et sparingly."
This suggests that emulating Bjørn's behaviour with frequent use of rapid charging is not recommended -- another semi-warning, as made famous by VW's vagueness over the eGolf...
Incidentally it also says this:
Trickle charging:
When you can not run into a general ladddstation due to low battery, you can charge the car through the portab- la 220V charger with ICCB (ingåen- the control box for cable) that can be purchased as an option. Trickle-charging recommended one- DAST in an emergency, as electricity can cause problems with the electric bill and electrical stresses."
This suggests that the car does not come with a granny-charging unit as standard..!
