Hi
@yoh-there
Again thanks for your input and "CanZe" Excellent bit of work
Maybe some confusion here as unlike a BCI (Which I have had several of already trying to use the dodgy chargers around Sheffield). There was no spanner with this situation.
(Now I am at home on a PC I will type it out the way it happend (Sorry will be a bit long winded but at least it will show all details).. And I must say at this point that all the Rapids that gave problems I have used before in the last week or so with NO Issues at all on the Zoe.
Arrived at Harvester Flamstead with about 40miles left on GOM, After 140 Miles or so drive from home,
Harvester Flamstead (Polar Ultracharger). Activated with RFID, Selected Type2 Plugged in, Plug Locked to car and dash showed Ongoing Checks, but unusually the Charger kept showing Connect to Car. After a couple of mins Charger clicked and Card flashed red with error. Unplugged it and tried again, same outcome but this time as well as car showing Power Cut While Charging Charger went to Red X on Screen with message Wrong Cable Type Or Cable Error.
As soon as cable removed from car, errors on dash cleared no spanner nothing left to suggest an issue.
Put it down to a Faulty Ultrachager (Not Uncommon), and moved on to the Holiday Inn just down the road
Holiday Inn Luton South (Polar Ultracharger) Same Outcome as above. Except this time I tried the lock and walk away went to loo etc and let it reset between tries. Final outcome the same with the Red X on Charger.
Decided to move onto Watford as plenty of posts to Try.
BMW Watford (Polar Ultracharger) Same Issue as Above.
Decided now to change tack as Asda Was Next Door. Went to Asda and tried the 7kw post Polar. That charged but was showing a charge time of over 14 hours, didnt plan to stop there just wanted to check charging system was serviceable so I could carry on
The Grove Hotel Watford (Polar Ultracharger), Leaf had just plugged in so could not use
Holiday Inn Watford (Polar Ultracharger), Same outcome as first couple of attempts PowerCut When Charging on Dash (That went away without prmopting as soon as cable removed) and Red X on Charger
At this point had 25 Miles left so decided as we knew 7kw was working to Limp to Central London
On Way stopped at a Brent Cross Underground Station and tried the ESB Triple Header, This one was different as unusually it had CCS and Chademo showing on screen but no Type2 Button, plugged in type2 anyway, but after a while it came up with a connection error message. Cant say this was the car as it could have been charger so moved on
Parked up at Regents Park on the Polar 7Kw Posts, I spent 6 hours sat there while Vicky and Kids shot off into London do do their bits for the day.
After that we headed up the M1, Stopped at Milton Keynes Coachway.
Milton Keynes Coachway (Polar DBT Rapid) Selected Type2 Plugged in Few clicks Charger Errored and Locked out Type2, Same Power Cut Message on Dash.
Went a bit further up M1
M1 Newport Pagnall Services
EcoT Rapid was on Free Vend so tried it, (Same Result as MK Coachway)
RFIDd into the 22Kw Post, car charged straight away. No Errors
Tried the EcoT Rapid again, this time it worked fine,.
Carried on the the DocMartens Factory in Rushden, And from there across to the Holiday Inn at Kettering
Holiday Inn Kettering (Polar Ultracharger) RFIDd in Selected Type2 and it worked straight away. Wandered over to the Harvester and got a meal.
Was there 57 Mins and went for 30% to 92% (28Kw ish). Happy with that as a lot of the charge was in the slower above 50% selection.
From there onto home no issues plugged in and charged overnight at home no issues.
Maybe I am mad and should have thrown in the towel and got recovery after the first few issues, maybe its gone forever maybe it will be back next week, Dont know, But all I can say is the entire time I was sat there trying this I had the IT Crowds "Have You Turned It Off And On Again" Ringing through my head!
