I have picked up on an interesting complaint in a Mercedes EQ forum that I am hoping can be explained in more detail by knowledgeable folk here like @Jeremy Harris 😉
Someone is finding that if they use the granny charger the actual range for the SOC is reduced and in worse case scenario the SOC shows 25% remaining but the range says 0 and the car will not run. They have experienced the issue both in an e class PHEV and an EQS.
They have got a technical answer finally from Mercedes after the local garages indicated there was no fault or issue and it is that the granny charger is delivering insufficient amps for the car system to register them during charging. It seems the typical charge received with the granny charger is 1.7 to 2kw. Mercedes apparently do not see this as a fault as the cars are designed to be used with wallboxes.
I would be interested in someone explaining to me how they think the situation arises, partner suggests it could happen as the car circuitry will not be receive sufficient power but those with more knowledge might have other thoughts.
I must admit a PEHV powered by a granny charger seems ok but to try to run an EQS with a 110 kw battery seems unrealistic but the original poster is upgrading.
His view is that Mercedes are at fault and the car should not behave like this, mine by the way is fine on a granny charger the few times I have used one. It is apparently an issue unique to Mercedes.
I also wonder if the low charge rate due to low power at the plug in site may be an issue in the way that I only ever get a max of 6.8kw normally 6.7kw from my wallbox clearly due to our variable voltage supply.
Anyway I am interested in others thoughts.
