This morning my daughter managed to catch her bag on the charging door as she got into the rear of the car. It caused a black plastic coated springy metal component to come off from the charging door.
Nothing appears to be broken, just removed from it's normal location.
However so far I haven't worked out where it should go, I guess the upper slot in the hinge is a prime candidate. The charging door still has a spring mounted on the hinge, making it pop open when the release if pulled (still probably more reliable than many Ampera then
Any ideas, or could someone post a closeup photo of there hinge?
