Coolant replacement data
12K views 70 replies 12 participants last post by  Lasvegas666
I'm still getting coolant drop almost what, 2 months after the replacement - I know that actually the amounts are relatively small, but to be honest I'm getting a bit worried. Am I going to be the next one with a drained inverter ?
anyways, I'm not aware of how many people are finding the same issue - lots seem to have been given a spare bottle, but how many are using it ?
If it just drops a bit below the top marker (but still between the min/max) perhaps don’t top it up. Just mark the level with a sharpie whilst car is off and cold. See if it continues to drop over some extended time. Maybe it will stabilise?
I’m just wondering if you are topping it up very high when it’s cold then as it warms up it’s expanding and pushing it out of the tank top? Then appearing lower when it’s cold again.
Note that the level varies a lot with ambient temperature changes, that is normal. As long as it is on or above the min mark, there is no need at all to top it up. Just a thought anyway. Peter
I have mine done tomorrow. I will ask for a bottle right from the get-go so I don't have to return as it is an hour away.
I am also going to ask for a credit for the price of a coolant replacement. I have pre-paid for 5 years of servicing so I have already paid for the next coolant change so I feel I should be due a credit.
I'll let you know how I get on :)
Just had my inverter coolant replaced at same time as 3-yr service.
Asked for take-away coolant for any drop in level afterwards - refused claiming they'd not had a single case of needing top-up afterwards ( "& it's very expensive and they don't have any left over anyway" !! - yeah right).
I was also planning to try get a coolant-change credit as I'd prepaid for a coolant change in the 3-year service plan. I.e. on the assumption that KIA would be paying the dealer under warranty too. To make sure of my ground I asked if my service plan had been with Kia or them (dealer) and it turned out my service plan was with Kia. So I've paid Kia for a coolant change and they've provided one ... albeit it with weeks of dashboard warnings obliterating other information.
Same here.
I had mine done under the recall. They said they have done 22 changes and not had a single one return yet. I too asked about getting a credit on the service plan and I was told to contact Kia. I'll be doing that next week.
So far though, it is 3 days and I have not had a low coolant message. I haven't checked the reservoir yet.
I marked the reservoir after the coolant replacement and it's dropped about 8 mil in the 3 days since.
More worryingly, I'm now getting the amber "Check EV System" message and warning-triangle.
A read around this seems to implicate HVAC and/or a '3-way valve'. I'm not sure whether the 3-way valve pertains to the replaced 'inverter coolant', but a career in IT tells me that problems are usually caused by change, so I'm suspecting the coolant replacement is implicated somehow.
#13 ·
I'm currently topping up to max every time it drops - not marking the reservoir, but mentally making a note of how much I have to top it up by. The only "good" news is that the amounts are actually relatively small, but the "tool" all the dealers were waiting for obviously isn't very good. TBH, I've not got a happy feeling about this - where is all this coolant disappearing to - inside the inverter ?
#15 ·
I agree, and hope you're right - but remember we've all been told that noone has been back for topups, and that we all had to wait for the "correct tools" and that the job takes 3 hours to make sure there's no air trapped. It's all getting a bit weird - especially when you think that the change is so that "if" the coolant leaked into the inverter, it wouldn't short it out.
Any thoughts on this?:
Picked up our Niro this morning after having 3 year service and coolant change. After about 15 miles the car gave a big lurch (like almost stalling a ICE) and a warning flashed up and off.
Getting home and switching off get a warning message about electrical system fault, take to dealer.
Call dealer who were quite unhelpful. Just asked us to take it back so they could look at it.
Took it back (another 20 miles for 2 cars!) met by Service Manager. He takes car away for 5 min then comes to say ‘air has got in’ and they need to re bleed, which I take to be they didn’t bleed it correctly.
Leave it with them for 1/2 hour. On return told that they’d flushed the coolant on instruction from Kia, during the fluid change, and it has disturbed a load of ‘lime scale’(?) They’d flushed out all they could but think some is in the coolant pump and intermittently stopping it and throwing the limp mode and warning.
They’ve ordered a new pump and will have the car up to a week.
I understand the basic idea but it’s full of holes Who would make a coolant with water hard enough to deposit lime scale? What else could be precipitated? How will they know they’ve cleared it all?
The car had run perfectly for three years until I let them get hold of it. Now it’s OTR!
#19 ·
This is exactly the kind of scenario that I’m paranoid about. Mine is due 3 years service soon. Everything works perfectly but I’m dreading giving them the keys. I don’t trust them an inch frankly. There won’t be any limescale, thats just typical made up BS. Also, I doubt an airlock or contamination debris in the coolant system would cause an Electrical systems fault message. Was your car subject to the inverter leakage recall? I wonder if they had it apart and messed something up? What’s the betting after replacing the coolant pump it’s still not right? Have they given you a courtesy car?
I almost feel like not taking it in for the service, even though I’ve paid for next 3 services and MOTs!
Peter
#28 ·
Doesn’t make me inclined to believe what they told you about 22 coolant changes done with none coming back does it? If they had given you a part used bottle, you could have topped it up yourself!
This whole blue coolant saga is a total dogs dinner. Add to that that the coolant flush service campaign and that some of us have the inverter internal leakage threat/full recall!
That PDF coolant flush work instruction is a real golden nugget find! Thanks. I read it through and see I t’s an incredibly long winded and complex process and has loads of scope for the numpties getting it wrong I reckon.
My car is working perfectly at just 9k miles. I’m completely dreading it going in in September for 3yr service with coolant change (maybe the debris flush process too? Though I’ve not been notified about that one) and presumably the inverter leakage recall which I received. I haven’t booked it in yet but probably should soon as it’s prepaid MOT is due then also.
Has anyone managed to find the KIA PDF work instruction for the inverter leakage recall? I would love to read that one and see just what they intend to do with my car. Peter
Thanks Peter, your input is always useful.
I haven’t heard anything about an inverter recall. They did say when I took the car in and when I collected it that they needed time to carry out the coolant change and flush but I can’t see how a coolant would be made that would cause a residue.
Time will tell but if it’s not right after the pump change I wouldn’t be surprised.
What an indictment that they can f up a perfectly good car with ‘routine’ work.
We need to look at the next block of servicing. At the moment the last thing we’ll be doing is renewing with the same dealer.
#22 ·
Looking on line I found this recall bulletin which sounds like what they’ve told me. Is this the inverter thing you mentioned?
So that's the mysterious tool...
Not sure if it's the same issue regarding coolant warning messages, I have read the Hyundai cars (Ioniq 38kWh and the Kona's) have seen the low coolant level warning over the past 6 months or so. It was discovered the coolant was 'crystalizing' causing blockage in the battery cooling system (also used to cool invertor), hence the warning.
Apparently it was due to the 'incorrect' coolant being put in at factory, and the new type is labelled BSC-2.
Reading online a special tool had to be prvodided by Hyundai (probably Kia too) to flush out the air lock coolant system.
Due to this issue was was put off buying a Kona 64kWh and was looking at an eNiro.
This put me a little unease, knowing I HAD to take it (if I had bought one) to the dealership for a service. And like @prawlin not wanting to give them the keys to potentially break an otherwise perfectly fine car.
#23 ·
It was discovered the coolant was 'crystalizing' causing blockage in the battery cooling system….
That sounds more likely than ‘lime scale’!
I think what I’m being sold is that they’ve flushed the old stuff out to get rid of whatever the ‘debris’ is but haven’t got it all and some is fouling up the pump so they’re going to change that.
The question remains why a pump intermittently being stopped or slowed would make the car go into limp mode for a split second.
Why, oh, why are main dealers so poor at maintaining their own products? There was another Niro having the same process done today when we took ours back.
I’m beginning to fear the worst but even if we get the car back working properly I think we’ll consider chopping it in in the next year or so.
#29 ·
Had my coolant replaced on June 28th on our Kia Soul EV and we’ve done almost 800 miles since then and no coolant level drop since it was replaced.
The Kia Dealer that did the replacement did say that to ensure that they get rid of any air bubbles was to run the pump on their replacement kit for 30 minutes, after they’d put new liquid in, not the few minutes they were told in the Kia literature that they were given originally.
The work took just under 3 hours to do.
The service manager told me that using that system, they have never had a car come back for coolant to be topped up, but gave me a 3Ltr bottle of it just in case
#30 ·
Re the bold... boy, you have a good dealer! I ask for some and they refused. I have had to go back once already and I wouldn't be surprised if I have to go back again... but not yet.
#33 ·
I been looking but can’t find any official documents for that.
I’m still hoping that the dealer isn’t totally bullshitting and that properly flushing and fitting a new pump will sort things. I’m not entirely confident though but if they can’t do the job they’ll be in trouble because I understand they’ve got quite a few to do.
The car has been faultless over 3 years and 19k miles. It’s so disappointing that it does that then gets FUBAR because they can’t carry out what should, at the end of the day, be pretty routine work.
#34 · (Edited)
Must be something about car dealerships in Yeovil.
Back in 2000, I imported a new Audi TT 225 from Belgium for my birthday treat and a few months later I was going to our place in The Lakes and had a warning light come on in the dash, so called in there on my way to the M5.
Told them it was an import, although identical to the ones the dealer had and I had a warning/fuse problem.
The sales manager had the car taken into the workshop straight away where they removed all the fuses and cleaned all the contacts and the car arrived back outside of the showroom after they cleaned it.
The service manager then handed me a pack of 2 of each fuses in the box, together with a 3Ltr bottle of OEM engine oil.
When I asked how much, he said “nothing sir, maybe the next Audi you purchase you’ll come to us for a good price”.
Now that’s service for you. 😀👍
#35 ·
My word, if I was within reach of that dealership I would certainly switch my business in a heartbeat. A 3l bottle of the blue stuff is worth about £35!
My impressions of my local (West Yorkshire) dealership so far are that it is crap. You get the distinct impression when you walk in that customers are nothing but a nuisance to them. They left the brake fluid (under cap) filter off at my last service and threw it away! They vowed to get me a replacement when I complained the day after but it never happened. When asked, the mechanic apparently said he threw it away because it isn’t needed! Peter
  • Sad
Reactions: Snaxmuppet
#36 ·
I won’t name my dealer but on the surface they don’t appear too bad. It’s just that in the execution you get the feeling that they don’t actually mean much of what they say. Late for pick up, rarely clean the car though they say they will, never have courtesy cars, won’t collect, feed you condescending lines to excuse mistakes etc.
Thetford is quite a run for us, though I think we’ll try Norwich next time. If we still have the car.
#37 ·
4 weeks on and the coolant has dropped below the minimum. Galling given that I'd asked for some coolant to bring away in case this happened and it was refused because "no-one's ever reported a drop in coolant after the process" - grrr. I wonder how many have actually looked under their bonnet since having it done. Interestingly it dropping below minimum hasn't triggered a "refill inverter coolant" message! (yet).
The "Check EV System" warning has returned intermittently. This started straight after the coolant change. Further reading suggested a link to the PTC Heater coming on, but in may case it's happened without the heater coming on.
So it's another 40 mile round trip for a coolant top up and attempt to read an intermittent warning if it actually got logged - feels like a long shot.
Might be time to get a code reader and software.
#38 ·
You've probably read this on other threads, but I think it was my 4th revisit for topup when I finally "demanded" some spare liquid. I am still topping up even now after 2 or 3 months I think it is (difficult to remember!) - it's worrying, and all the dealer could say was "if it keeps dropping, bring it back and we'll have a proper look". Which basically translates into we'll keep your car for a week, find nothing, and still tell you no-one else has ever had the problem. This issue is becoming a real insight into just how dishonest these main dealers can be. No better than back street cowboys. It's seriously making me want to sell up before something goes bang, but at the moment, we couldn't take the financial hit, and I'm not even sure I'd stay with an EV TBH, which is a travesty.
