This function allows you to warm or cool the vehicle to an optimal temperature before starting your journey. You don't have to set a temperature yourself, as e-Remote Control will always aim for a comfortable temperature of 21°C.
General conditions of use
If you use this function while charging, the vehicle will be ready for use at a comfortable temperature and with full range.
When you program the pre-conditioning, the system starts between 30 and 45 minutes before the chosen time in order to be certain that your vehicle reaches a comfortable temperature, and remains active until 10 minutes later. It is therefore the time at which you will use your vehicle that must be programmed.
Depending on your vehicle’s equipment, you can also, from the touch screen of your connected navigation system, program the charging time via the "Charge" page of the "ELECTRICAL" menu and program the pre-conditioning times in the " OPTIONS” on the “AIR CONDITIONING” page.
The
first activation of the remote pre-conditioning feature will only take place if there are at least 45 minutes between the time you define this programming and the time chosen to start.
Once you have programmed a remote pre-conditioning, the instructions are stored in the vehicle and will apply even if the vehicle is outside the coverage area.
The doors and trunk
must be locked. If you unlock the vehicle during pre-conditioning, it will stop after 1 minute.
The charge orders requested while pre-conditioning is active will be taken into account by the vehicle and will be launched when the pre-conditioning is stopped. Warning: an information message may be displayed on the application.
Special conditions for plug-in hybrid vehicles
Initiating remote pre-conditioning will interrupt the charging of your vehicle if it is in progress. Charging will resume at the end of this programming if the terminal does not prohibit it. If the battery level is below 20% and the vehicle is not charging, the pre-conditioning function is not available/active.
Special conditions for electric vehicles
While fast charging, there is no limitation on the simultaneous operation of pre-conditioning and vehicle charging. However, while trickle charging, the outside temperature is a condition:
- Between 5 and 35°, pre-conditioning and charging can work at the same time
- The launch of a remote pre-conditioning program will interrupt the charging of your vehicle if it is in progress. It will resume at the end of this programming.
If the battery level is below 50%, the pre-conditioning function is not available/active
