In a closed regenerating system then these problems go away. So it makes sense for static, large scale sealed systems. It is my considered professional opinion that anyone peddling this as a means for quick car recharging are peddling snake oil, and I won't change that opinion until it's available to buy from a pump. It never will, not in my lifetime, I would put good money into that bet.
Forget it. People are out to swindle investors/Gov grants here, stay very very wide clear of getting involved in anyone claiming to be able to do this.
If there are any genuine researchers and business investors that think this comment is gratuitously wrong and they have a serious proposition, do PM me, if it makes sense I would be a very strong advocate. Very happy to have a technical discussion about it with anyone who takes this stuff seriously.
Completely agree.
I've looked into them a little and flow batteries in EV's will never happen, for a few reasons:
1) Energy density both volume and mass is a long, long way behind even current Lithium Ion technology, let alone the promised, fabled solid state electrolyte designs that are (hopefully) on the horizon in the next few years, with no real way to increase the density. (How can you increase the density of a tank of fluid ?)
Including the tanks and the pumping system they're big and heavy for the amount of energy they can store. That reason alone makes them impractical on a mobile device like a car where energy density is everything.
2) Power density is even worse in relation to Lithium Ion. For a given Ah capacity the peak power discharge and charge rates are WAY lower than Lithium Ion. This is fundamental to the design of having only a small portion of the electrolyte in the reaction chamber at once - power output (and charge rate) is limited by the surface area between the electrodes, and if 90% of your Ah capacity is sitting in a tank at any given time and only 10% is in the reaction chamber then your power output in relation to Ah is only going to be 10%. On the other hand all of the capacity of a Lithium Ion battery (and most other kinds) is available at once as all the electrolyte is "active" and available between the electrodes at all times.
So even if you could stomach the weight, size and complexity (pumps, filtering etc) the peak power output/input for acceleration and rapid charging rates would be painfully disappointing. Power output is also linked to flow rate, so at higher power outputs/inputs you need to pump the electrolyte through faster so it isn't as responsive as a normal battery design to large changes in output, (like suddenly punching the throttle) and yet you don't want to be pumping it through at maximum speed all the time either, so it isn't well suited to rapidly changing loads.
So what's so great about flow batteries ? They have two main strong points:
1) They scale up well to large Ah capacities - instead of having to make more and more cells, you can scale up the Ah capacity simply by having larger electrolyte tanks. Tanks are very low tech compared to the complexity of making lots more individual Lithium Ion cells.
Every extra cell you add in a Lithium Ion pack statistically increases your risk of a cell failure, and some battery packs designs do not cope with failed cells. If they are all in series for instance like they are in an i-Miev (or Leaf ?) a single cell failure makes the whole pack useless. You can work around this in a parallel/series design like Tesla use where you have groups of 12 individually fused cells in parallel, with each group then connected in series - which will survive individual cell failures, but at the expense of additional complexity. (Individual fuse wires etc)
A bigger flow battery tank is fundamentally not any less reliable or more likely to fail than a small flow battery tank. Of course if you need higher power output or charging rates, you need a larger reaction chamber as well, but many applications like grid storage can make do with a very high Ah storage capacity with a modest power input/output rate.
2) In theory a flow battery can last "forever" with no Ah capacity degradation at all. This is also useful in something like grid storage - if you use current tech Lithium Ion batteries in grid storage today gradually they will lose their usable capacity, and then what do you do with them when they reach end of life usable capacity ? Flow batteries solve that by theoretically not degrading at all. Whether this has been proven in real world use yet I'm not sure.
All of which means flow batteries are the perfect choice for grid storage to help buffer peaks and dips in demand and make renewable generation the majority generation in the country. For stationary storage it doesn't matter how big and heavy they are if they are exceptionally reliable and long lived, and an already functioning flow battery can even have its storage capacity upgraded on the fly without shutting it down simply by building another pair of tanks and connecting them to the flow.
Not suitable for EV use whatsoever though, regardless of whether you charge them or use electrolyte swapping - anyone proposing this simply hasn't studied their properties, and you don't have to be a battery expert with a university degree to understand why they're not suitable.
