How the hell do you change the pollen filter in a 2020 Leaf?
1.6K views 15 replies 7 participants last post by  SMLMcKenzie
I've tried to get into mine and it's almost impossible and it seems the existing one is wedged in there good and proper.
I just did mine & it's a struggle....You need to collapse the filter to get it out...Have you removed the glove box? Pull the top towards the bottom & then pull out (I know that sounds easy----it's not). If the last person put it in correctly there is a pull on the bottom of the filter to help remove it. To reinstall you have to collapse it to 1/2 it's height & slowly feed it in & up at the same time.
Yes---My car was "serviced" before I bought it 3 months ago....I'm an old mechanic (45 years-retired) & not only was the cabin filter not "replaced"....the final drive fluid was not changed....so much for "service".... I also follow My Nissan Leaf Forum & put the slightly lower-weight final drive fluid in for better range. I live in a hilly area (Southern Oregon) & average 4.2.
To be fair, changing the oil in the gearbox is not on the maintenance schedule of a Leaf...so a dealer following the standard schedule won't be doing it... Nissan probably figure it will make it to the end of warranty without failing without changing the oil so why bother... (am I cynical ?)
Still a good idea to do it though. On some EV's the recommended interval is 50k miles.
I saw about the oil change in the transmission thingy and was getting a quote off Cleevly's in the UK. It was surprisingly competitive, so will get it sorted when I get paid at the month end.
Would I be wrong in having a hunch that main dealers aren't doing much, if anything, when servicing an EV?
#9 ·
I changed the reduction gear oil/final drive fluid in my van-based car (which has the same reduction gear as a LEAF apart from different size cogs to give lower gearing). It's a do-able DIY task, and worth trying with the best quality compatible oil (ATF meeting Nissan Matic S grade) you can find. There's an excellent YouTube video by @Dalathegreat and a write-up by me at https://www.speakev.com/threads/reduction-gear-oil-change.171737/
They are very good at taking your money. They do that very competently and efficiently.
Marginally less sarcastically, they ought to be checking the brakes and adjusting the mechanical parking brake, then replacing the brake fluid every few years. Most of the rest is the same checking done for an MoT.
#13 ·
I took my I Pace to a small independent (HEVRA) garage for servicing, rather than the main dealer. Not much cheaper, but what they did do was show me the service parts they'd replaced, including the pollen filter they'd taken out.
I think smaller garages very much rely on recommendation and word of mouth from satisfied customers in order to be able to compete, so maybe they are more likely to be open and honest?
#16 ·
I changed the pollen filter in my Leaf this year for the first time due to no longer having to have the car serviced by the dealership to keep a third party warranty valid (ditched the warranty).
It is a pretty easy DIY job. Just remove a few screws, pull out the glove box and pull out the filter (the trickiest bit). Took me less than half an hour and only cost me £12 for a Bosch filter. Way better than the £179 (!) Nissan charge. Total rip off. The Hevra garage I asked also charge nearly the same. You feel like you are being robbed to maintain the warranty. The service itself does nothing for the battery so it is 100% about fleecing their customers.
Will be taking the car to an independent next year to get the brake fluid changed and not paying Nissan £229 to get it done.
