2,781 - 2,800 of 4,649 Posts
Had ours for a couple of weeks and loving it so far. Is there a way to change what's displayed on the instrument cluster screen? For example sat nav map etc? Mine just has the Speedo on. Also my "auto wipers" aren't actually automatic, I have to flick the stalk up and down for them to start. Anyone else had this fault? Sorry if it's been posted, there's alot of pages!
I set my instrument cluster to the satnav option which is by far the best. I think it's the button and twist on the end of the indicator stalk.
Got mine serviced last week. They did lots of updates and fixed a problem with my AC, the drain hose was kinked and made my passenger footwell damp if the AC was On.
The regen B mode now works at 100% which is very nice. Hopefully this means the fast charging is faster now too.
I noticed that now the super pessimistic guessometer is an optimistic guessometer, perhaps it just hasn't recalibrated to my driving style yet 😉
To change the cluster you twist the end of the left hand stalk which rotates through different options. Each option may have additional options accessed by pressing the button on the end of the left hand stalk.
Auto wipers are enabled by moving the right hand stalk up one notch. It will show they are enabled on the cluster screen. Good idea to not have them on all the time, if they are frozen to the windscreen and try to go off then it could be an issue.
Discussion starter · #2,784 ·
Auto wipers aren't automatic. You have to keep turning them back on again. Never had auto wipers stick in frosty weather as the car is always defrosted before I get in. Far easier to turn them off on the odd occasion it's an issue than have to keep turning them off and on again each time you get in the car and it might rain.
Thanks alot, got the maps on there now and it's brilliant!!
Is there anyway to make the infotainment screen go full screen? At the moment it's a centered box and there's loads of wasted space. I've looked in the manual I promise 😇 I've attached an image incase I'm not clear
Yeap, for example now I'm watching TV whilst the car charges however it would be much better if the screen wasn't so small.
Especially when you paid for a larger screen :) (7" vs 10"). It does seem like a lot of wasted space
Oh, and can't say I've ever watched anything on the infotainment while charging - will have to give that a go
Reactions: Pharris3267
Looks like an update to the Android app. Changes say:
"Bug related to the usage of your e-command service and to the performance of your application"
Be interesting to see if there is any noticeable difference in reliability with the e-commands. I think a lot of the problems stem from the fact it requires the SIM to have good reception.
Is it just me or did the Trips tab dissappear on the app?
I just updated to version 1.33.0 on Android.
Probably going to trade in our 3 years old Mini cooper at the weekend for a low mileage Sept 2020 Elite Nav in white. Have read an unhealthy amount of this 140 page thread, but still have couple of questions.
1) I see it has a charge timer so you can use Eco7. My BMW 330e allows me to set a window for the charge so it only charges within that time. The posts I've seen seem to suggest the Corsa only has a 'delay' timer (like a TV sleep timer) so you could only set the start time; if it needed more than 7 hours charge, it would keep going using the more expensive daytime rate?
2) The car we are looking at has the range indicator with 8 bars in it. I believe this means its not using the latest bios. Is there a version number or something I can quote (which will mean more that just saying 4 bars vs 8 bars) so I can insist the dealer installs it, before we agree to buy?
3) Can the proximity lock/unlock be turned off fully so you can just use the button? I have it on my BMW and it's a bloody pain in the arse and never does what you expect it. Worst part is when you get home and want to plug in the charger, the car locks itself before you get a chance to plug in because you moved 6 inches too far away from it! I have to sidle around my car like a bloody thief so I stay close enough or the flap locks before I get to it.
I might have move, but that's it for now. TIA.
Discussion starter · #2,796 ·
@Gary Brown
Charge end time or percentage can't be set. It's annoying.
The proximity lock and unlock can be turned off. It's not bad actually. It unlocks the charge socket automatically when you're close enough anyway so if you do go out of range and then go back in range it isn't too much of an issue as it'll just unlock it again. It's a manual push flap to open and push close so it's not like the electric ones that fling it open and then shut it just as you reach it.
Lack of battery percentage is annoying. It's on the Mokka so there's no excuse. There seems to be too many versions of updates and dealers aren't always the best at making sure their cars are fully up to date.
@Gary Brown
Something my £45k BMW isn't capable of. It its lock and you've put your keys away, you gotta get them out whilst holding the charge lead in your other hand....
Just watched a comparison review on Youtube between Corsa, citroen and 208. Felt a bit of a hatchet job. Reviewer claims in 8 weeks of winter use he never saw more than 133 miles range on a full charge and that you can forget about the rear seats if you are over 9 years old... Would anybody on here agree with either statement before we go ahead with our purchase?
Discussion starter · #2,799 ·
Rear access is awful. Door opening is poor. It is cramped and awkward. Never use rear seats for people but even a cat carrier was tricky to get in and out.
Winter range was about 130 odd miles I found. Reviewer knows his onions when it comes to EVs. He had the Corsa for a reasonable amount of time.
Has anyone got confirmation of service schedule?
One manual I’ve seen says yearly, the other every two years. Up until recently the app said November 2022 for me but now it’s updated to say I’ve missed a service and one is due in July. Meanwhile, the vehicle check feature on the car itself says it’s due one in 5 months.
Rang the dealer and they said two years but said it with some degree of hesitation.
