No camera signal received
1.2K views 15 replies 5 participants last post by  KiwiME
I've started to get a problem with the reversing camera. The headset displays a green screen say "No camera signal received".
Anyone be able to offer advice? I'm guessing back to the dealer but am a little concerned that we hit year 5 in July and I've read previously about lessening warranty cover as the years go on.
This first occurred 3 days ago. It sometimes works, others doesn't. Various posts on Google suggest resetting the head unit. This doesn't appear to fix it however. What does happens on a head unit reset is that, after the reset, the camera works for a split second then the head unit reverts to green screen.
Thanks for the input.
It's gone from an intermittent error to a continual one now.
I'll see if I can get the housing off to get access to the camera and check for water ingress. It would seem odd for this to be the issue though as the last couple of weeks have been the warmest we've seen all year, with absolutely no rain. Obviously this does not mean that water ingress is not the issue but the timing seems off.
I finally got around to dismantling things. So far as I can see the camera is a sealed unit. There's no obvious sign of water ingress. For now I'm just going to live with the lack of camera (it's the first car we've had with a reversing camera so not a great loss). Next service I'll check with the dealership if they cover it under warranty. If not I see there 3rd party replacement cameras available for around ÂŁ100 to ÂŁ150. I may eventually try one of these.
I don’t see why the reversing camera would not be covered. Had mine replaced under warranty at 2.5 years, same issues, but a blue screen displayed.
And have just had the AC regassed (again) after having new condenser fitted in July 2024. No evidence of leaks - holds pressure when tested - yet system completely empty of refrigerant when initially inspected.
We had the condenser replaced in October 2024 (along with the controller). In Scotland, we didn't have any reason to use the aircon until June this year when we discovered it wasn't working. My understanding is that it's a sealed system so assuming no leaks I don't understand where the gas can have gone to.
I had exactly the same discussion with my local dealer who did the work. They have no better idea to me how the gas could leak and the system then test and hold pressure again once empty. And the machines they use for the filling process do test for leaks before filling, and will not put gas into a leaking system.
So I’ll be keeping a close eye on the system again and checking to see if performance starts to drop off again.
#16 ·
The reversible-cycle heat pump is just like those found in homes, however there are several differences.
a) The cabin air path has separate heating (condenser) and cooling (evaporator) units. That means it can do dehumidification by using both.
b) There is just one compressor whose input and output is configured with valves as required. Because the compressor is electric it's a sealed unit like in a fridge, there's no shaft seal to fail like on an ICE car. That said, Hyundai-Kia seem to have found a way to make them break occasionally.
c) The battery has a dedicated coolant chiller (comprising an expansion valve and heat exchanger) which cools the coolant circulating in a loop through the pack.
d) The battery also has a dedicated PTC resistive heater, used for heating the 'coolant' as required. I think it's about 2.5 kW.
e) The cabin has a PTC resistive heater (not shown in the image below, about 3.5 kW) to supplement the heat pump when it's de-icing, or when it's just too cold to be effective. When you smell a hint of burnt dust, that'll be the PTC stepping in.
When driving there's no significant warmth to be had out of the battery or any other component. To heat the cabin you need multiple kilowatts and that quantity just isn't available from anything other than the outside air.
When DC charging the battery heater kicks in when under about 20°C, drawing power from the charger up to about 2.5 kW. It warms it at about 1°C per minute. When driving with Winter Mode on it heats the battery (reportedly) when under -5°C to avoid the BMS imposing power restrictions that might happen from under about -20°C (approx).
When minor battery cooling is needed, typically for higher-level AC charging, the battery is cooled 'passively' using coolant circulating through the radiator.
The complicated schematic is for the Kona but it's all the same for the eNiro as best as I'm aware. I've marked it up as best as I understand it.
