I have just opened up a Zappi which had stopped working, I traced the power up to the front panel but no display. I removed the WiFi pcb and now it boots up. Can these be purchased?
Yeah tried that a few times, it lights up ok without it plugged in. I was going to see if it was able to connect to a hub but probably won'tDid you try just reseating the module a few times.
It's been know for laptops to not boot with anything from a CD drive to the HDD itself being the culprit, WiFi cards and RAM which works perfectly well when tested have also been a cause.
I always found reseating everything as the first thing to try is usually worth the time even if it just confirms the first suspicions.
The connecters don't look pristine so reseating might help.
Gaz
