It's a claim made by infrared panel manufacturers.
If you stand in front of the panel it may make you feel warmer than otherwise in a room heated by a radiator, but it's not otherwise going to warm the room more than any x kW source.
This is the reason pubs/outdoor areas use infrared lamps to heat up open areas. Almost anything else would be ineffective as you would need so much power to compete with the outside air cooling it down. But for a bedroom I would have thought IR is not great. Unless ceiling mounted?
Mine is wall mounted, quite low at the foot of my bed. If it turns out not to be good enough, I might mount another on the ceiling, but that will be more difficult to wire - unless I take it off the lighting circuit? A 720w panel only draws 3 amps, and I've replaced all my lights with LEDs - if all the upstairs lights are on (which they never are at the same time) that's only 500w, so it'll probably be fine - but I doubt it's a good idea. I'd appreciate some input from someone like
@Jeremy Harris here.
In the kitchen/living room, I'm planning to put one on the wall next to the sofa, warming me when I'm watching TV or gaming, and another ceiling mounted above the dining table, taking the power from the upstairs ring main.
I won't know for sure until winter - I'm hoping not to use my gas heating, but I won't disconnect it until I'm sure. The panels aren't expensive, so I could cover the ceiling in them if that seems necessary.
