Ohme Go 3-pin to Type 2
Message
6.3K views 5 replies 5 participants last post by  Andrew Sheldon
Check price
I'm looking for an Ohme Go 3-pin to Type 2 EVSE if anyone has one they no longer use?
#4 · (Edited)
Just to help widen your search, you can buy any Ohme Home Go or whatever you like to call them (the name seems to vary, even on their own web pages).
You can then have the wire changed or otherwise fit some cord with a 3 pin plug to power the device up.
Once working you can contact Ohme and get them to make a change (over it's 3G / 4G connection) to set it to charge at 10 amps.
I would join some smaller flex to the existing cable to retain the IP rating but see separate threads about water ingress. That way you don't have to disturb the label which has connection details you'll need.
There is one on ebay right now actually...
HTH
Gaz
Reactions: Harry6
Hi Gaz, I have an Ohme charger I bought for my Leaf it has Type 2 input and Type 1 the other end. My Go Faster is ending soon and I want to use it if possible. However I now have moved house and can only granny, I can contact Ohme and get the charger downrated.
The Type 1 can be swapped out for a Type 2 or I can get an adaptor.
The Type 2 however has a handshake, can you tell me what type of adaptor I need by any chance?
