Pre-Conditioning... Brrr
6.6K views 17 replies 13 participants last post by  Biggles
Hi all,
Well it's back to work for me and a frosty start up here in Preston. The car is new to me and I'm yet to figure out the pre-conditioning settings. Nothing appears to happen when I use the fob. Please can someone explain how the car needs to be setup the night before for this to work? Are there any visual ques from the exterior that pre-conditioning has started?
It was rather chilly nipping out in my dressing gown this morning to 'start' the car! :ROFLMAO:
Cheers,
Jim
Yes, it is the flashing lights that tell you.
Lock the car, lights will flash, then press and hold the precon button on the fob until the lights flash again.
The green light on the dash will change from short flashes (charged) to continually on (drawing power from mains). It is worth keeping an eye out for the continually on green light. I have had two occasions when the precon started but was drawing the battery down rather than from the mains.
Reactions: RickMGoldie
No, doesn't need to be plugged, but obviously will draw on battery if not. Uses around 0.8kWh for the first full preheat at 0C, then another 0.4kWh for the second. You can do up to 2.
You do really need a preheat these days because it's the only way to demist windows from a cold start. I tend to set it 5 mins before leaving work (no plugin then), it'll use around 0.5kWh and I'll set it to 'HOLD' or 'MM' straight away as I need to burn a bit or petrol to make my commute anyway, so might as well get the 'free heat'.
It uses a lot of energy from the battery to precondition the car so yes it needs to be plugged in. There's no settings to cause it to happen automatically, you have to manually start it going in the morning when you get up using the key fob.
#7 · (Edited)
Just to my experience if the EML light is on for any reason ... the precondition will not work, or start.
For me there is no need to press and hold the lock button.
Just press lock on the remote (indicators flash) and then within 5 seconds just press and hold the remote start button (indicators flast and the side lights will light up (front and rear)) now release the precondition button.
According to the manual is will run up to 10mins like this and then it will stop unless manually interupted.
The side lights remain lit up for the whole duration while the precodition is running.
One more thing I noticed is that it will remember the Climate settings from the last time you used the car (ECO-MIN-MAX mode), so it you want it to warm up nicely ..then leave to the MAX the night before. Well this is what the manual says at least. :)
As many said best to use it with the car plugged in to electicity point.
Enjoy :)
#9 ·
The sidelights come on if you had DRLs set at the last power off.
I tend to leave sidelights ON when powering down (the sidelights then go out). This turns DRL OFF and disables the sidelights when preconditioning. (You might not want to draw attention to your car when it is in this state.)
Reactions: VasilisKent
The manual has all sorts of useful information in it, you know - might be worth a read ;) :rolleyes::whistle:
#16 ·
Yes.
Just the same as heating, set the temperature, leave in eco or max mode.
The windows will open if you hold the unlock button on the keyfob. Handy to let hot air out as you approach in summer. The fob has quite a range 👌
#18 ·
The preheating is a great feature. Mine works from the third floor up in my flat with the car in a concrete garage at ground level. I just hold the fob out of the window, press the button and it warms up while I have breackfast. The only disadvantage is the beep it makes when you press the button means all my neighbours know I have an early start. I wish the been could be quietened down but apparently it can't be.
