Yes indeed, I agree, the 62kWh battery pack has three strings of cells -- and this allows it to charge more rapidly than the earlier (two-string) battery packs. Details at
Nissan Leaf - Battery Design
But ... a fastcharger has a maximum-available output amperage. As pointed out by Graeme Hart on the NZ EV Owners Facebook group: "The 62 kWh leaf can't charge any faster than any late model leaf on the Chargenet 350 kw hypercharger as the charger has the older standard Chademo connection. It can charge faster on chargers like the one at Farmer Autovillage in Mount Maunganui."
CHAdeMO 1.0 cables are limited to 125A. CHAdeMO 1.2 allows 400A.
125A*375V = 47kW, which corresponds very nicely to the 44kW max of my 24kWh e-NV200 (until its SOC is above about 40%). And the 300kW hypercharger at Bombay NZ (a bit south of Auckland,
Motorway Service Centre | PlugShare) advertises that you'll get only "50kW" from its CHAdeMO plug -- which is within cooee of 47kW. So: Graeme's explanation makes a lot of sense to me.
If you're at a charging station which can supply 200A at 375V, then you could charge a 62kWh pack at 75kW -- which corresponds nicely to Nissan's (amended) claimed max-charging rate for their 62kWh packs.
And... if you ever find a CHAdeMO station which can supply 300A, then you
might see a 100kW charging rate... but that'd be a pretty fast charge (above 1.5C) for the NMC cells in a Nissan battery, and there's no active cooling on its pack for the Leaf... so the pack will heat up significantly if this charge rate is sustained for more than a few minutes. I'm therefore
guessing that Nissan stopped advertising the 100kW charging rate for the 62kWh e+, after its engineers had revved the firmware in the charging controller to make it possible to take hot-weather roadtrips (without much risk of overheating the battery to the point that it won't take a second fastcharge on the same day).
I have had my share of overheating issues, although to date I have always managed to avoid the dreaded turtle mode from an overheated battery! My preference when charging my 24kWh e-NV200 on a roadtrip is a 25kW fastcharger, because these sessions won't add much if any heat to an already-hot battery. By contrast, a 50kW fastcharge session will heat up its 24kWh battery pack when charging up to (very roughly) 60% SOC; then the chargerate will drop below the point (very roughly 25kW) where the (rather wimpy) active-cooling system on my 2014 ex-Japan e-NV200 will start to make some headway against the heat generated by charging. As always, "your mileage may vary", because there are so many important factors which will affect chargerate curves: firmware version, battery SOH, battery starting temperature, ambient temperature, ...
The Nissan LEAF was one of the first electric cars with lithium-ion batteries on the market. Overall, it was a good EV, but with a major weak point.
insideevs.com
The Nissan Leaf is perhaps the iconic original OEM BEV. Interesting how it performs against the competition over the years.
www.batterydesign.net
