Renault Zoe Q210 range extender
18K views 49 replies 16 participants last post by  RiverRock
I have been thinking about adding range extender generator option to my Q210 for some time now and would like to exchange ideas with you to explore possibilities. Initial calculations say that with just 3.0kW generator my Zoe could travel around 300km @70km/h and around 230km @80km/h with gasoline consumption around 2.5-3 litre / 100km. Of course, all those are all just theories and will have to be (dis)proven in real life testing. ;)
First, connection to the battery bus - best place and most logical candidate I found is battery disconnect "switch" under the floor on the front right side in the cabin. It has to be modified with external wires and connected via fuse to Anderson (or similar) connector where generator will connect.
Second is the power source - there are multiple possibilities (e.g. expensive DC power sources with additional conversion losses from regular 230V AC generator), but the simplest and cheapest one I found is 3-phase power generator with full bridge rectifier to produce needed DC voltage. Standard 380V AC generator is producing around 540V DC, so it has to be rewound to 28% lower voltage to get 390V DC. Of course, there's also a question of the generator location - it can be on the trailer (pitty that option is illegal since Zoe doesn't specify tow weight on the homologation), it can be in the boot (needs good air flow for cooling, getting out exhaust pipe, sound proofing, loss of space in trunk...) or it can be on the roof racks (possible if the generator weighs less than 70kg, needs to be enclosed in the waterproof box).
So far, so good - but that is leaving us with third part of the puzzle...
The car itself - how will the electronics in Zoe react to fact that you are adding power source between the battery and inverter? In the best case car will see that now it is using less power (e.g. 4kW from the battery instead of 7kW assuming generator is providing 3kW) and enable driving longer distances. In the worst case, car will see that current in the battery (if there's such measurement) is much less than current in the inverter and it will raise error and refuse to drive on.
So, my question is if someone has already tried something similar? ;)
And of course - all comments and ideas are welcome!
Kresimir
My suspicion is the answer is No. People have probably dreamed but never got around to it. I suspect that if you have the time and the expertise to do this you'd be better getting additional paid employment and spending the extra money earnt on an i3 REx where someone else has done all of the work for you.
If you are doing this for the learning experience Emile at Muxsan has done work with his CANBridge on the Zoe so might be able to offer some advice with specific issues and @Toomba seems to be able to fix most things.
Reactions: farmergiles
In the era where batterries are more and more affordable, more energy dense etc - doing this seems counterproductive.
A 55kWh battery can be fit in the OEM battery box without modifying it. This capacity allows you to drive, day and night, a Zoe. Much easier, safer, more space in the boot and any other argument proves this.
Sent from my SM-A405FN using Tapatalk
#9 ·
For around 200 miles, certainly. Then you are stuck without anything more than 22kW charging unless you fit a CCS or CHAdeMo. But it should be more than adequate for most people in that type of car.
#15 ·
I drive a ZE40, if you can call my car like that. Have not encountered a destination I could not drive my car to.
As for charging during driving, it's possible.
But your set up lacks safety features, you could easily weld shut your contactor. Think about safety as well.
#16 ·
We have to get to our vacation home where there's only one questionable 11kW charger on strech of more than 200km and the terrain climbs more than 900m, so even ZE40 in the winter is questionable if it could reach destination if that one single charger is down.
That is very usable info, thanks!
What should I do for safety in order to prevent welding the contactor?
Is the problem only if genny is running while car is turned on or being shut of (which can be prevented manually by turning it on/off in correct order)?
#19 ·
Went today to Car Inspection Station and found out one interesting thing - although Zoe is not allowed to tow the trailer, towing hitch can be installed for other usages like bike or cargo carrier.
Seems like a much better genny location than in the trunk or on the roof.
Seriously, where to mount the generator is the least of your worries. The best thing you can do is brick the car, that way you won't cause any further injury to yourself or others. To do this safely needs deep knowledge of the car systems and ability to modify the programming logic. Doing it unsafely might work, but I very much doubt it's legal and certainly not wise.
Reactions: cah197 and JDleaf
#34 ·
Not sure if these guys ever got it working: Product — EP Tender
They were proposing a generator in a trailer or a battery in a trailer - can't see the generator option now.
I can absolutely see the use case for this. Not necessarily with a Zoe, and not in such a DIY way as was proposed by the OP. But if someone had a solution to make long haul towing with a larger EV that has a usable tow capacity a feasible thing, I would buy it. Range will always drop massively with any sizeable towed vehicle (large caravan ). Yes I know there are micro-caravans targeted at the EV towing market but they all require you to be very small and have take little or no stuff with you on holiday. So in practice, if you have a large towed vehicle - you don't tow it with an EV (unless you are willing to take the same hair-shirt approach to journeys as the EV pioneers did 10-12 years back).
If you could safely put a range extender in the towed vehicle, that can safely range extends the EV for long trips, you've solved the "EV's aren't usable in practice for long haul and/or heavy trailer towing" problem. This problem is the exact reason I still retain a diesel 4x4 for towing my caravan on holiday. For all other trips, I use an EV.
#29 ·
I dont know about Q210 but my R240 has a unused 400 V connector for PTC heater, I use it to tap in to 400 V bus and run the house with my 30 kWh SitePro GE ups.
This would be perfect for your extender, no need to modify anithing, you only need to buy pins for the connector .
Zoe is fine with charging or discharging through this connector to about 20-25 A , I use it often, it has 32 A fusses inside and it is energised only when you turne the car on and 5 minutes after you turn it off, so it's mutch safer then emergency disconnect.
The only thing to worry about is never shut down the car when there is external power source charging the car, if you do that you will brick the car and will need the diagnostic computer to clear the fault.
I have done it one time :)
#30 ·
Please don't do this. You want to connect directly to the high voltage system without can bus? Yeah there is HV positive and negative in the safety pull out in the drivers foot well. Literally full pack voltage right there so if you pull it out and then slip and put your fingers in it when you're not wearing the correct safety gear then you'll go off like a firework.
There are only big fuses on the HV system, not breakers like you have at home. You'll die long before the fuse blows.
#36 · (Edited)
In your opinion, what sort of size document would be needed, like how many pages to make at least a safety manual so that a person who understood electrical things quite well wouldn't need to guess and risk harming themselves or the vehicle?
I genuinely think it would be a good thing to help people be safe when they work on their cars. To say "just don't touch" when it's not more dangerous than any other electrical installation of similar voltage is wasted on people who wouldn't touch anyway and to withhold safety information is dangerous to those will do it anyway.
#37 ·
You've already demonstrated the point by saying its not more dangerous than any other installation with a similar voltage because if you consider a 240v home system as being "similar" then its really not. Home electrics have circuit breakers that cut off the power before you die. 350-400v EV batteries are protected by a fuse that is around 300amps and your body is not conductive enough to blow that so if you connect your skin with the HV battery then it'll kill you and it'll hurt the whole time you're dying.
Cheers.
#38 ·
Of course household is not the same voltage as an EV but in your house even a 2 amp fuse is not going to trip if you touch a live part so whether we're talking 300a or 2a fuses, they are there to protect the house. Don't expect any personal protection from an overcurrent device.
I do accept there is usually an RCD to protect people in a house and not in the car but then again, RCDs are not by any means guaranteed to trip just because you touch a live wire, for example. Depends as I'm sure you know on many factors.
When you work on household electrics you should always cut the power before you start whether there is an RCD or not.
The same should apply to cars of course.
A quick question, do you earth the car before working on it?
#39 ·
Hi, no you dont earth a car before working on it because other than while charging the car is not meant to have a reference to ground and it being earthed wouldnt stop you being hurt. You hit the nail on the head when you said you'd cut the power first - cars have big orange safety cutouts which is great, however as I think we said above when the fuse is out in a Zoe there is full pack voltage in that socket and if you're working on the battery then you've got high voltage right in front of you and no breakers to save you.
Pic of my morning so far...
Cheers.
#44 ·
I had a charging issue on the Zoe and I wanted to see where in the BCB the fault may have been. I saw a video of a garage repair and the guy was saying the diagnostic showed that it was a specific component of the BCB that was at fault which is the level I would like to have. He didn't mention what kit he had and I can't justify Renault.net subscription but the icarsoft i907 is affordable or is it something higher up the scale that i'd need?
#46 ·
Good project. Although I didn't get from that video what the ECU would do about drawing current from and regen charging with two different batteries. It would be good to know how that guy got the various systems to "accept" and work with the other battery or maybe that is not an issue. My Zoe has two battery banks with two BMSs I believe. If you just paralleled another battery on top I would expect issues.
#47 ·
I think that the main reason he got it to work was that it was a from the ground build up. He didn't have to deal with the manufacturers system.
There are several videos of the conversion. You have to dig deep in his videos, it was done ages ago, but they are extremely interesting.
#50 ·
On a Zoe, for AC the motor is used as part of the rectification - so I can't see how that would work.
For DC I guess it would be possible if the batteries were being charged in the same way that regeneration happens when you brake. So if extender was providing the right voltage in parallel to the motor and batteries - it could charge the batteries when the motor was taking less than the extender was outputting (in the same way that a 12V battery charger works in all cars).
I suspect there would be some serious software updates required to stop it barfing though!
