Hi all,
Been on the forum for a while now but on just registered as never had an issue that hadn't already been asked before.
Ive got a Sync EV Charger fitted at the start of the year and for the most part it's been fine, occasionally unable to start charging from the app but unplugging it and reconnecting has fixed it.
The other day the charger wouldn't start charging from the app, just froze on the preparing message. So unplugged the cable, normally this will clear it. Plugged it back in and still the same. Tried to reboot it via the app and it wouldn't reboot. Restarted phone and tried again and it rebooted. Tried again to start charge and froze again, so unplugged it again. Turned the charger off at the isolation switch, waited 30 seconds and turned it back on.
I now have a flashing led ring on the charger. The app says "rebooting, please wait" it says you can use the RFID card to start the charge but this doesn't work either. So I waited an hour, turned the charger off and waited 30 seconds and then back on and it's still the flashing red light.
When I try to reboot the charger it says no connection, unable to reboot.
An email has been sent to support@syncev.co.uk by the company who installed the charger asking for them to run diagnostics but doubt this will tell them anything as there is no connection. I've had no reply from them as of yet.
Has anyone had anything similar? I was thinking perhaps it's a WiFi issue, how are the router settings added to the charger so it can access the internet?
Thanks for any advice,
Dan
Dan
